· Mustang Member
trojans 86
so whats that wild car run?
also, afr heads are a good point to set your sites, they are an excellent head, may second only to canfields
your car would really wake up with a set of 3.73 or 4.10 gears
good luck man!!:)
· Mustang Member
Don't know what its going to run. I'm still working on it. Doing weight removal and fibrglass replacements at the moment. It feels strong on the street, but won't hook up. 4:10 gears are in it's future. Do you think the AFR heads would help a lot over the Edelbrocks?:?:
· Mustang Member
afr heads
while the edlebrock heads work well they just arent the best
from what ive seen in flow numbers i like canfields the best but afrs are a close second
head flow numbers dont mean jack though if you cant get the potential air to the heads (i.e. t/b, intake, etc)
also once you get all that air in there you will need some good flowing exhaust
head flow numbers are as follows:
edlebrock 226cfm/175cfm @ .600 lift
afr 185's 282cfm/191cfm @ .600 lift
Canfield 258cfm/195cfm @ .500 lift
flow numbers are in./ex. respectively
at onlt .500 lift the canfields really impress me with some minor port work they could be an ass kickin head that could be bolted to a near unbeatable street car
i also heard something about hyd roller lifters being too heavy for high rpm cars so soilid lifter may be in the future as well
later dude
