That's good to hear. What does that switch do?jaytyn said:Faulty Inhibitor Switch on the Transmission!
Can you notice the difference with the inhibitor switch replaced, ie does the car feel more relaxed when cruising(the engine doesn't sound too elastic bandish), reason why i'm asking is i might have to findout if dads car might need this switched replaced. At 120km/h the trans should lockup, but it doesn't seem to do it.jaytyn said:its the switch that reports to the ECU what gear the transmission is in apparently...
When it was faulty it was stopping the torque converter from locking.
Well the way the transmission locks via the lockup clutch, it feels direct when you accelerate, just like a manual in gear. However when the lockup clutch is not locked the revs will rev up around 500 rpm before speed increases to make the pulling more pronounced. I hope what i'm saying makes sense.jaytyn said:
Hi EF,
Well I havent really took my car on speeds over 100's since it was in the accident.
I have been in town, I am waiting to get a weekend off work, so I can go for a drive to Wagga for the day.. (2 hours away).
How can you tell when the transmissin locks?
