1 - 9 of 9 Posts
Discussion Starter · #1 · (Edited)
hey guys, may be a silly question but im think that i need some new foam for more horn... last night at 3 in the morning my horn just started sounding and wouldn't stop til i unplugged the battery. it happened a couple of months ago aswell but stopped as soon as i put the key in the ignition. as far as im aware (from what i've read and heard) there are a couple of wires separated by a bit of foam and if that foam disintigrates then you cop a rude awakening like i did last night! can anyone confirm this and where/how to fix?? thanks heeeeaps!
btw its a 94 ed classic
Sandwich Connoisseur
Just cut yourself a new bit of foam. Get the old piece out and take it to clark rubber and get them to do the rest.
Territory TS - AWD
Yep, happened to mine too (ED not Territory).
There is a thin splice of foam the seperates the horn contact plates. Once it desintegrates (~10yrs in my case) the plates can come into contact as if you are pressing the horn.
Just stuff some more in there, I used a piece that I ripped off an old sponge.
It takes all of 5 minutes and it should be good for another 10 years.
From experience the double sided self adhesive foam tape used to attach car trim also works Ok too (but it is a bit stiff needing firm pressure on the horn boss to blow the horn). The rolls of draught excluding self adhesive foam tape (buy from any hardware store) is better.
Did you ever figure out the solution? I have the same issue. Mechanics disabled horn but several things do not work now because of it.
You have tagged on to a post over 16 yrs old with no chance of getting a reply from the op . Start a new post if you are looking for help in the correct section for whatever vehicle you have .
1 - 9 of 9 Posts
