the horn on my 95 mondeo has stopped working, when i press the steering wheel sometimes the horn works if i have recently started the car, but most times it doesnt work. Could this be a faulty relay? if so how can i test the relay to see if it is faulty. apparently the relay also controlls the hazard lights which are working fine. if i have to take off the airbag to get to the horn ring and see if anything has come loose, how dangerous is this? im worried about setting the airbag off by mistake.
The drivers side door will lock but not unlock when using the key in it. - any help there?
the engine sound a bit thumpy / rattly when moving off in first gear with the revs up - any ideas why?
thanks,
thanks,
