i use a meguiars gold class polish , gives a awesome shine for about a month then is gone soon after.....reason being its made up of special oils and washing the car strips these off.....
You can't really polish (wax) your car too much, every 2 months is good, every month is even better. Don't leave it longer than 3 months if it's in the sun a lot.
BTW, you really mean wax it, as polishing is taking a fine layer of paint off every time.
If paint is well looked after, that is waxed often enough, you won't have to polish it.
Only polish if the paint has lost it's shine.
Polish also 'cuts' the paint slightly, otherwise it wouldn't be called polish.
There are many different grades however, and depending on how bad the paint is, determines what grade polish to use.
Always finish with a wax.
The easiest way to tell if it needs it or not is to run your hand over over the paint work after you wash it. If like is smooth like glass then its fine. If the paint feels rough then it needs a wax.
That's not quite true.
If the paint feels rough, then it needs a polish.
If the paint feels smooth, but 'grippy', thn it needs a wax.
If the paint feels smooth and 'slippery', then it's likely fine.
Can't wax a car too much no such thing. Usually for newer cars a fine polish is whats needed as it cuts alot of the small stone chips and excess touchup paint (small white bits on the bonnet that i really really hate) out but doesn't takeaway the paint. After a polish the surface should be waxed to seal the paint otherwise the paint will be due for a polish again.
