Status
Not open for further replies.
Subaru/Ford guy.
How-to's for multiple makes and models of Ford:
Visual-mods:
http://www.fordforums.com/f769/how-paint-your-wheels-174647/
. http://www.fordforums.com/f769/how-paint-your-valve-cover-174650/
Video - http://www.fordforums.com/f632/resetting-pcm-after-repairs-made-202913/
Video - Ford 4.6L & 5.4L 3V Spark Plug Removal
Video - Ford 4.6L & 5.4L Broken Spark Plug Extraction
Video - 6R60 & 6R80 Fluid Level Fill & Adjustment
Maintenance/tool mods:
. http://www.fordforums.com/f769/how-...urus-escape-flex-am-fm-radio-problems-174684/
. http://www.fordforums.com/f769/how-...owntube-several-different-models-ford-173982/
. http://www.fordforums.com/f769/how-c6-trans-oil-pump-assembly-178818/
Extra Ford info:
. http://www.fordforums.com/f769/how-calculate-cubic-inches-4-stroke-engine-180863/
. http://www.fordforums.com/f769/fyi-why-you-should-flush-your-trans-178819/
. http://www.fordforums.com/f769/does-my-car-have-obdll-178827/
. http://www.fordforums.com/f769/ford-351-windsor-cleveland-engine-specs-178834/
. http://www.fordforums.com/f769/tsbs-ford-500-montego-sable-taurus-mks-178842/
. http://www.fordforums.com/f769/ford-maf-178851/
. http://www.fordforums.com/f497/302-351c-stroker-info-129316/
. http://www.fordforums.com/f769/429-460-cam-valvetrain-interchangeable-178835/
How-to's for the Ford Contour:
Visual-mods:
. http://www.fordforums.com/f769/how-change-speed-sensor-178789/
. http://www.fordforums.com/f769/how-transmission-range-sensor-178790/
. http://www.fordforums.com/f769/how-backseat-removal-178807/
Extra information:
http://www.fordforums.com/f769/diagram-fuel-tank-178969/
How-to's for the Ford Escort:
Visual-mods:
.http://www.fordforums.com/f769/how-2000-window-problem-179162/#post1365943
Extra information:
http://www.fordforums.com/f769/99-2-0l-info-179045/#post1365534
How-to's for the Ford Mustang:
Visual-mods:
. http://www.fordforums.com/f769/how-1990-ford-mustang-5-0l-rpm-tach-174811/
. http://www.fordforums.com/f769/how-alternator-voltage-test-178820/
Extra information:
http://www.fordforums.com/f769/2001-v6-ect-temp-volts-chart-178821/
How-to's for the Ford thunderbird:
Visual-mods:
. http://www.fordforums.com/f756/how-change-n-switch-97-thunderbird-178787/#post1364545
Extra Thunderbird information:
http://www.fordforums.com/f35/random-things-auto-owners-should-know-167360/
http://www.fordforums.com/f769/3-8l-fi-6cyl-specifications-178833/
How-to's for the Ford Galaxie:
Visual mods:
How-to's for the Ford Falcon:
Visual mods:
. http://www.fordforums.com/f538/20-cold-air-intake-35768/#post385867
How-to's for the Ford Focus:
Visual-mods:
Video - http://www.fordforums.com/f769/ford-focus-window-regulator-problems-201826/
Video - http://www.fordforums.com/f769/ford-focus-engine-mount-vibration-repair-201818/
Video - http://www.fordforums.com/f769/ford-focus-suspension-rub-creaking-noise-repair-201810/
Video - http://www.fordforums.com/f769/valve-cover-gasket-oil-leak-repair-zetec-2-0l-ford-focus-201786/
Video - http://www.fordforums.com/f769/ford-focus-front-suspension-rattle-noise-repair-201882/
Video - http://www.fordforums.com/f769/ford-focus-spark-plugs-replacement-201890/
Video - http://www.fordforums.com/f769/ford-focus-brake-repair-201906/
. http://www.fordforums.com/f769/2000-2004-dual-gauge-cluster-pods-how-174604/
. http://www.fordforums.com/f769/2000-2004-change-cluster-mph-rpm-color-how-174609/
. http://www.fordforums.com/f769/2000-2004-dual-air-vent-gauge-pod-how-174606/
. http://www.fordforums.com/f769/how-license-plate-lights-177128/
. http://www.fordforums.com/f769/how-00-04-g2-m3-focus-powered-mirrors-177955/
tool mods:
. Custom made tools for the focus.
Maintenance/FAQ'S:
. http://www.fordforums.com/f769/motor-mount-wears-too-quick-178659/
. How-to: Brake master cylinder.
. http://www.fordforums.com/f769/00-04-front-end-clunk-179055/#post1365562
. http://www.fordforums.com/f769/how-remove-focus-headlight-bulb-00-04-a-179072/#post1365629
. http://www.fordforums.com/f769/how-shifter-base-replacment-180207/
D20-D23 DOHC:
. http://www.fordforums.com/f769/how-duratec-2-3l-thermostat-175594/
. http://www.fordforums.com/f769/how-fix-04-zts-2-3-auto-trans-p0767-code-problem-176043/
. http://www.fordforums.com/f769/how-remove-mtx75-d23-177097/
. http://www.fordforums.com/f769/how-remove-altenator-03-ztw-2-3l-180600/
Zetec DOHC:
. http://www.fordforums.com/f769/how-p-s-pump-zetec-dohc-177205/
. http://www.fordforums.com/f769/how-c-delete-zetec-dohc-177324/
SPI SOHC:
. http://www.fordforums.com/f769/vac-line-diagram-179047/#post1365543
Extra information on Focus:
http://www.fordforums.com/f769/ford-focus-bulb-sizes-178755/
Broken Gauge cluster fix.> http://www.fordforums.com/f769/broken-gauge-cluster-fix-178023/
Focus DTC Fault codes.> http://www.fordforums.com/f756/focus-tdc-codes-2000-2008-a-177158/
Focus test mode procedure and some DTCs> focushacks.com test mode/DTC codes.
How-to's for the Ford probe:
Visual-mods:
.http://www.fordforums.com/f769/how-ford-probe-rear-brakes-176410/
How-to's for the Ford Fusion:
Visual-mods:
Video - http://www.fordforums.com/f769/ford-fusion-blower-motor-chirping-repair-201834/
How-to's for the Ford Crown Victoria:
Visual-mods:
. http://www.fordforums.com/f769/how-replace-98-crown-victoria-water-pump-175561/
. http://www.fordforums.com/f769/how-remove-remote-mirror-switch-178831/
. http://www.fordforums.com/f769/how-air-ride-spring-conversion-178843/
. http://www.fordforums.com/f769/how-panther-t5-swap-178849/
Extra information:
http://www.fordforums.com/f769/crown-victoria-history-178850/
Victoria
blinker issue fix
> Curtsey of PHoganDive
How-to's for Ford Town car.
Visual mods:
http://www.fordforums.com/f769/how-convert-older-town-car-seats-have-seat-switched-178456/
How-to's For the Ford Grand Marquis:
Visual mods:
http://www.fordforums.com/f769/how-grand-marquis-window-motor-bushing-replacement-178455/
http://www.fordforums.com/f769/how-ambient-air-temperature-sensor-178829/
How-to's for the Mercury Mystique:
Visual mods:
Extra information:
http://www.fordforums.com/f769/fuel-tank-diagram-1999-a-178956/
How-to's for the P71:
Visual mods:
http://www.fordforums.com/f769/how-axle-seal-replacement-178830/
Visual mods:
. http://www.fordforums.com/f480/how-install-midrange-speakers-into-falcon-door-165677/#post1315106
How-to's for the Ford Taurus:
Visual-mods:
Video - http://www.fordforums.com/f769/ford-taurus-rusty-coolant-flush-procedure-no-heat-201842/
Video - http://www.fordforums.com/f769/ford-taurus-heater-core-removal-201850/
Video - http://www.fordforums.com/f769/ford-taurus-common-issues-no-heat-201858/
Video - http://www.fordforums.com/f769/ford-taurus-thermostat-change-201874/
How-to's for the Ford Tempo:
Visual mods:
http://www.fordforums.com/f480/how-remove-aftermarket-radio-173050/#post1342793
Trucks/SUV/Van/Minivan How-to's:
How-to's for the Ford escape:
Visual mods:
Video - http://www.fordforums.com/f769/ford-escape-abs-tone-ring-install-201778/
Video - http://www.fordforums.com/f769/ford-escape-front-brake-repair-201794/
. http://www.fordforums.com/f769/how-replace-idle-air-control-valve-ford-escape-175711/
How-to's for the Ford explorer:
Visual mods:
Video - http://www.fordforums.com/f769/ford-explorer-coolant-leak-radiator-repair-201754/
Video - http://www.fordforums.com/f769/ford-explorer-front-hub-bearing-growling-noise-repair-201802/
. http://www.fordforums.com/f769/how-explorer-liftgate-glass-applique-65751/
. http://www.fordforums.com/f769/how-repair-spring-jammed-door-pics-178805/
How-to's for the Ford Expedition:
Visual mods:
. http://www.fordforums.com/f769/how-heater-core-98-a-178958/
Extra information:
. http://www.fordforums.com/f769/03-ford-expedition-tech-service-bulletins-178801/
How-to's for the Ford ranger:
Visual mods:
. http://www.fordforums.com/f769/how-video-bleeding-ford-ranger-clutch-176386/
. http://www.fordforums.com/f279/how-1995-2-3l-timing-belt-replacement-170387/#post1333092
. http://www.fordforums.com/f769/how-install-replace-power-door-actuator-178828/
Extra information:
. http://www.fordforums.com/f756/ranger-tps-voltage-chart-178802/#post1364603
. http://www.fordforums.com/f769/interchangable-ranger-parts-178803/
. http://www.fordforums.com/f769/3-0l-head-bolt-specs-178804/
. http://www.fordforums.com/f769/how-self-test-fuel-injectors-178930/
How-to's for the F150/250/350:
Visual mods:
Video - http://www.fordforums.com/f769/7-3l-powerstroke-cold-no-start-diagnosis-glow-plug-relay-201866/
Extra information:
F-150:
5.4L-3V-6R80-HARSH 1-2 UPSHIFT
F-250:
F-350:
http://www.fordforums.com/f769/83-84-fuse-box-diagram-178837/
. http://www.fordforums.com/f769/83-84-hazard-exterior-body-light-wiring-diagram-178838/
How-to's for the E Series trucks.
Visual mods:
http://www.fordforums.com/f769/how-change-brake-pads-87-econoline-178797/
How-to's for the Ford Freestar.
Visual mods:
http://www.fordforums.com/f61/2004-freestar-heater-core-r-r-how-182473/
Note:
as always, if you have a how-to you would like me to add, contact a Mod or Admin by PM with the URL link to the how-to.
Status
