My daughter and I were trying to remove some suspension bushings on her Mini Cooper. The tool I bought should have been able to remove them with the bushing bracket in the car.
But the back of the puller went sideways and bent the threaded rod. I think this was because of the twisting force on the rod let things get mis-aligned and I didn’t see it until it was too late.
Would an old hydraulic throw out bearing have enough force to move a stuck suspension bushing if it was used in a puller assembly?
I can adapt it for use on my Porta-Power, and that would be better than cranking on it with a wrench.
One last note, I pulled the bracket out and put it in a 12 ton hydraulic press. It was hard to move even then.
Thoughts?
If you search "mini front control arm bushing" on YouTube there are several videos covering this job that may help e.g.
and
but it does look like one of those jobs that make you think about trading the car for something easier to work on.
