1 - 9 of 9 Posts
i dare u all to figure this one out.. I have a 91' escort gt my girlfriend was driving it and it started to bog and die,so she claims. got it home took it off the trailer and cranked and cranked.... it fired but barely... well i put her in the shop and kinda forgot about it for a while so now if you turn the key to run the dash lights come on as they should but the fuel pump don't hum... turn the key to crank and it doesn't crank but the fuel pump runs! It almost seems like if u could just crank that key a little farther shed go... well i tryed an ignition switch and the same problem... any ideas?
thanks
cliff
try the fuel pump relay and the connections to the starter motor
TurbolaserS
It won't be timing,it's definately ignition.Is the coil or distributor?Fuel pump relay is a good idea but what about a dodgy ignition barrel??
TurboLaser
that stuff all sounds prety logical but why does the fuel pump not run untill key is in crank position? and i was playing with it and got it to crank over and fire up but barly then it died and same thing cant even get it to crank again it seems so odviou that its the ignition system but what?
thanks guys
Lord of the RC
Wouldnt you have nothing, not even a fuel pump if it was the coil or electrics ?
My old escort died totally and wouldnt turn over or anyhting, tho that turned out to be the starter motor
When the coil in my EL went i didnt get a fuel pump or anything ?
Chris
1 - 9 of 9 Posts
