1 - 10 of 10 Posts
My 1970 mustang ignition switch is stuck in the "start" position. Linkages and connections seem fine, switch moves freely but continues to run the starter...and nobody makes a replacement switch, so I want to frankenstein a good one out of new and old parts. I want as much information as I can get before I start snipping wires...and neither my Chilton's nor my Motors repair manual has the diagram I'm looking for. 7 wires coming off the starter switch; yellow, black with a green tracer, pink, red with a blue tracer, purple, red with a white tracer, and another black.:driver:
Discussion Starter · #5 ·
nope, I love the fact that they sell a starter switch with a pre-cut pigtail for $90... when you can just buy the $20 version underneath it and cut the wires yourself.
Administrator
Yes you have to wonder sometimes but they do have a big range of some old and difficult to find parts that can get you out of a bind.
Premium Member
I dought you have an ign. switch problem. You probably tried to start the car with a low battery and the contact disk in the solenoid arced and welded closed keeping the starter engaged. Replace the solenoid and see what happens. I've been wrong before.
good luck.
FYI, found them on Ebay, also a push button conversion, but I think CHipset is probably right.
Discussion Starter · #10 ·
I think Chipset was right, I charged the battery, plugged the ignition switch back in, and the car started fine. can probably chock it up to a bad solenoid switch, I just bought it a month ago, here's hoping I can find the receipt.
1 - 10 of 10 Posts
