i have a 1993 f150 4wd with the 5.8l and a e4od trans. it shifts fine in reverse you put it in drive and you fell it go in but you have to accelerate it up to 2000 rpm to get moving then it shifts fine after that.i belive it is the selinoid pack but not sure was woundering any thoughts on this or if any one had a pdf manuel they could email.
First check fluid level and condition. If it seems fine, you may have fouling on the transmission filter. Drain and replace filter and fluid. They're can be other things involved that would require dropping the transmission and opening it up, that gets expensive real quick. I'd hate to go through all that work and money for a filter change.
Thanks for the input.i changed fluid and filter tonight.still has the problem.going to see what the pressures are in mourning
