Birth, Drift, Death...
i dont know how ford do their SRS, but if it was a holden you would need a new wiring loom and a different SRS module, and then have to re-program the instrument cluster as well.
you might be lucky with the harness, but im betting you will require at least a different SRS module as well.
Stupid lamas!!!
i think it would be a big job and is it really worth it?
kickerinthegutsbarry
What he said, and you really wouldn't want to find out wether they work or not, would you?
VENOM-AU2-XR8
i think it may be easy.. check if theres a Yellow insulated cable in the location where it goes .... I've got a workshop manual here, and it seems the Airbag modules wiring are the same.. but hey, i'm no ford engineer. so dont do it based on my opinion.. do some research, get a workshop manual!! :)
BTW, the AU2 fitted with a pass side airbag will also have front seat belt retentioners (which are also explosive driven off the airbag module)
