My dome light is not working with the switch on the panel, but you can turn it on at the lights. When this one went out, so did one side of tag light and one side of third brake light. Please help
Sounds like a broken wire, year and model may get you a schematic if it's an older one.
I'm not seeing a commonality between the items you mentioned without losing a lot of other items. It's possible that the other lights are coincidental, but I'd be looking at the switch on the panel as having failed. Check the bulbs and connections on the other lights.
