I had a bad blowout of my front right tire the other day and i found this plug undone. I'm not sure what it is and the Male end is wrecked. The pins are broken so that it will not reconnect. I'm getting several trouble codes now and not sure what all would be fixed by replacing this wiring. Before now the only trouble codes I have been getting are the crankshaft and timing ones which are a known issue. I'm mainly worried about the turbo, o2 and cylinder 3 misfire. I'm wondering what this plug actually is and which of these codes could possibly be corrected by fixing it. Any feedback would be greatly appreciated. Thanks...Chad... it's a 2013 f150 ecoboost fx4.
Sent from my SM-N975U using Tapatalk
You'll probably have to go back to Ford for the wire run. Other option is to get the connectors and splice in new wire. If you got the second route, remember to solder the wires, do not use spade connectors or wire nuts.
