Hi, I am having multiple issues with my 2016 Ford Escape with a mileage of less than 23,000. I am hoping someone can advise me as to whether these are all related or not.
1. OEM Head unit - It keeps showing the "do you want to turn on automatic updates" screen, I click yes, and finish. Then it will not recognize my phone and loses all my contacts, so I have to pair it again. The clock also loses an hour and I have to reset it. This happens several times a week. Occasionally, when I shut off the car, a screen pops up that tells me to shut off the car or I'll run the battery down, but the car is already off. Sirius also loses its signal regularly. So much so that I don't listen to it anymore. I have tried to update Sync, but I always get an error.
2. A few weeks ago, I got the "oil change required" message 4-5 times in 1 week. It has been less than 1,000 miles since the oil was changed. I reset it each time and it went away.
3. Then I began to have issues with the outside air temperature. The numbers were all over the place, ranging from -20 to 120+. I am in Florida and the correct temperatures at this time should be in the 70-95 range. Sometimes, there can be a temperature shown on the head unit and --- on the dash screen. If the temperature is low (below 40ish), then the AC will only blow hot air. I can get into the car and have a reading of 20 degrees, start driving and watch it increase to 100+ in just a minutes or so. I can shut off the car, get back in and its low again. Or I can get back in and it's too high.
Previous repairs include: replaced throttle body @ 5,768 miles, replaced PCM @ 6,132 miles, replaced battery @ 11,848, and battery again @ 16,526.
Am I looking at 3 separate issues or are they all related? (The 3/36 warranty has expired. Are any of these covered under something else?) Thank you.
First thing I would check would be the battery voltage . Get it load tested as a battery low on charge can sometimes cause similar faults like you are having .If it is the battery you might want to carry out a parasitic drain test .Or it may only need charged if lack of use or just used for short journeys .
I can do that, but I didn't think that was a possibility as the battery is less than 2 years old. The car starts right up and doesn't sit for long periods of time.
I like to eliminate the easiest , possible causes first before getting too involved .You MAY have separate issues or other causes . A faulty air temperature sensor is one quite common item on various makes / models that gives you crazy readings .
