Hey all
need some advise from you guys already running some bigger cubes. What Jet sizes for both the prim and sec and maybe power valves..
specs are;
408c 10.6 comp
268 272 dur 620 620 lift 112lobe
AFD 4V, TFC high plenum intake
C4 only 2400 stall at the moment
Caby is out of the box Proform 750DP....
can you say what you use and your cam specs pls...(c'mon brenx)
just a good ball park to run the motor in..... the proform comes with something like 74 in the prim and 80 something in the sec...
cheers all!!!
specs are;
408c 10.6 comp
cheers all!!!
