steering problem on 94 bronco
Hi--- first time at this ---hope I'm ok
Question--can anyone cure my steering problems????
I have a 94 full size with dual shocks,front & rear sway bars,factory alum wheels & correct size tires. just had the front alinged,4 new ball joints,2
new raidus arm bushings,cut rotors,new wheel bearings and it still goes
down the road side to side. must correct the steering from side to side constantly. it sucks big time. dont know where to turn next (no pun intended)
any help will be appreciated. thanks---jim-bo
Sounds to me like your power steering box is out of adjustment or on its way out. Adjusting it is a pretty simple task. I'll outline the task for you here if you feel like doing it yourself. If not, any competent shop should be able to help you out.
The best way to find the slop is to have a friend turn the wheel back and forth with the engine off while you look around for what's causing the problem.
Good luck!
