:AAHHH:
:AAHHH: yeah ive done it now :AAHHH:
just put an AU gearbox into my NA !!
biiiiiiig job but. where do i start ??
the main prob is that the gearbox crossmember is a bout 6" further back than the origianl 3 speed mount, whihc means that i had to cut away a bit of the original mount to fit the box in, and make up a couple of extension brackets out of angle iron to hold the crossmember. 3 and 4 speeds are same length so you dont need another tailshaft.
the au box that i put in also had different bellhousing and the inspection cover and the support arms wouldnt fit.
also had to change the throttle body (mpi) becase the extra tps required for the gearbox ecu would not mount to the original throttle body.
also had to cut the loom apart to get teh gearbox wires separte to the general car electrics (they all go in one loom throught the firewall)
had to change the shifter (extra psoitition for D), and the surround, as well as running wires to p/e switch, changing dash cluster and wiring up signal for tacho, p/e light / speed / ignition / battery power etc.
it took me approx 1 day to wire it up, and onther day to fit the gearbox.
ive still gotta do a couple of things, such as top up the fluid (which is a bitch now cos ive gotta drop the crossmember to get to the fill plug....AU's have no dipstick !!) and aslo sort out where the crossmember hits the exhasust sometimes.
also gotta chance the diff over (differnt ratio) and put the eb gears onto the extension housing that run the speedo.
i wouldnt recomemed this if you didnt have any idea on what you were doing.
if i was to do another one, i would get a smashed car that was mpi & 4 speed and just transfer over all the stuff....ecu, looms, throttle body etc. the only thing that wouldnt go straigt in would be the crossmember.
The end result is a car that now idles smoother, runs great, and should have good fuel economy once i change the diff & speedo gears. If i was planning on getting rid of the car, i wouldnt have bothered with a conversion this big & expensive, but since i plan to hang onto it for a while, it will be a good thing.
NEXT PROJECT.....NL FRONT AND REAR PANEL CUT ONTO THE NA , AND NF / NL TRIM CONVERSION!!!!
cheers
botch
cheers
botch
