Hi guys. I was attempting to recharge my ac system and pressure looked as though it was building on the low pressure side. Once the compressor kicked in a puff of what I assume was the refrigerant blew off in the air by the fender on the driver side and then i lost my pressure? Is part of the ac system on that side of the car? As you may assume I’m not a mechanic? Any suggestions would be appreciated?
The condenser runs the length of the radiator. If it has sprung a leak, the repair should probably be left to a professional. If there's air in the system (and if there's that big of a leak, they're probably is) part of the repair work is a proper evacuation of the system once the condenser is replaced.
