1 - 16 of 16 Posts
My son was driving my 2005 Navigator during the heavy rain Wednesday from the remnants of hurricane Ida. He says it slowed to a craw going up a hill even floored it wouldn't go over 1500 rpm (limp mode). He shut it down and went to restart and no crank, no start. I did have an OBD II in the car and he read to me these codes P0101, U0101, P0010, P0020, P0102, P0135, P0155, P0443, P0446, P2106. Of course a good samaritan stopped to help and disconnected the battery wiping out all the codes. I checked the starter relay and its good. I tried to start the car with a remote starter switch and the starter spun but did not engage the flywheel. I replaced the starter and no change. I'm starting to thaink its the ECU.
Any thoughts or help would be great.
Check for water intrusion everywhere. Pull the crank position sensor and let the connector dry out. And make sure all the fuses are good.
Quite a few fuses that could be linked to your non start
2005, 2006
Interior fuse box diagram: Lincoln Navigator (2005, 2006)
Advertisements
Assignment of the fuses (2005, 2006)
Amp RatingDescription
17.5 A*Run/Accessory - Instrument cluster, Front wiper motor, Rear wiper motor
220 A*Brake On/Off (stoplamp) switch, Turn signal/Hazard flasher, Stoplamps, Center High-Mounted Stoplamp (CHMSL), Turn signal lamps
37.5 A*Power mirror switch, Memory module (logic power), Driver seat switch (memory)
415 A*Rear seat audio controls, Navigation module, DVD player
57.5 A*Brake On/Off (stoplamp) switch, Powertrain Control Module (PCM) (keep alive power), EATC control head, Body Security Module (BSM) (keep alive power), Speed control deactivation switch, SecuriLock LED, 3rd row seat relay coils, Power liftgate module, Clock, Brake Shift Interlock (BSI) solenoid
615 A*Headlamp switch (parklamps and switch backlighting feed), Parklamps, License lamps, Foglamp relay coil, Trailer tow electric brake controller (illumination), BSM (autolamp parklamps), Floor console gear selector lighting, Foglamp indicator
75A*Radio (Start signal)
810 A*Rear window defroster switch, Heated outside mirrors, Rear window defroster indicator (climate control head)
915 A*Transmission control module
1020 A*Trailer tow back-up lamps relay, Trailer tow 7-wire connector (back-up lamps), Trailer tow parklamps relay, Trailer tow 7-and 4-wire connectors (parklamps)
1110 A*A/C compressor clutch relay, A/C compressor clutch solenoid, 4x4 Integrated Wheel Ends (IWE) solenoid
1215 A*Fuel pump relay, Fuel pump shut-off switch, Fuel pump driver module, Fuel pump motor
1310 A*Rear window defroster relay coil, A/C refrigerant containment switch, A/C de-icing switch, A/C low pressure switch, DEATC control head, DEATC solenoids, DEATC blower controller, Trailer tow batteiy charge relay coil
1410 A*Daytime Running Lamps (DRL) ignition relay coil, Trailer tow back-up lamps relay coil, Electrochromatic mirror, Back-up lamps relay, Back-up lamps
155A*AdvanceTrac® with RSC switch, Instrument cluster (Run/Start feed)
1610 A*ABS/AdvanceTrac® with RSC module (Run/Start feed)
1715 A*Foglamps
1810 A*Auxiliary A/C temperature blend door actuator, Auxiliary A/C front auxiliary control, Park brake release relay coils, Turn signal flasher, Electrochromatic mirror, Auxiliary mode motor
1910 A*Restraints Control Module (RCM)
2030A*BSM (door locks, liftgate glass release relay), Liftgate glass release motor, Left front window motor, Door/Liftgate lock motors
2115 A*Instrument cluster (B+), Interior (courtesy) lamps, Park brake release relays, Park brake release motor, Puddle lamps (outside mirrors)
2210 A*Moonroof switch illumination, Flip window switch, Flip window relays, Flip window motors, Electronic hidden antenna amplifier (navigation radio), Radio (delayed accessory feed), Left front window motor, Navigation module
2310 A*RH low beam
2415 A*Interior demand lamps (front map/dome lamps, glove compartment lamp, cargo lamp, roof rail lamps, vanity mirror lamps), Battery saver relay coil, Battery saver relay power, Heated Positive Crankcase Ventilation (PCV) valve, Heated PCV valve relay
2510 A*LH low beam
2620 A*Horn relay, Horns
275A*Brake Shift Interlock solenoid, Reverse park aid system module, Air suspension module (Run/Start), Compass module
285A*PCM relay coil, SecuriLock transceiver, Heated PCV valve relay coil
2930A*Trailer tow electric brake controller, Trailer tow 7-wire connector (electric brake)
3025A*PCM (4x4 transfer case clutch), Air suspension module (air spring solenoids and height sensors)
3120 A*Radio (B+), Subwoofer, Navigation radio audio amplifier
3215 A*Catalyst Monitor Sensors (CMS), 6-speed transmission (ignition sense), HEGO sensors, Canister vent solenoid, Vapor Management valve (VMV) solenoid, A/C compressor clutch relay coil, CMCV, VCT actuators
33Not used
3415 A*PCM, Mass Air Flow (MAF) sensor, Fuel injectors
3520 A*High beam headlamps, Instrument cluster high beam indicator
3610A*Trailer tow right turn/stop lamps
3720 A*Cargo area power point
3825A*Rear wiper motor, Washer pump (rear window wash)
3920 A*Console power points
4020 A*DRL relays, DRL foglamps, DRL headlamp relay coil, Headlamp switch (headlamps), Multifunction switch (flash-to-pass), BSM (autolamp headlamps relay), High beam relay coil, Fuse 25 (LH low beam), Fuse 23 (RH low beam)
4120 A*Cigarette lighter, OBD II diagnostic connector
4210 A*Trailer tow left turn/stop lamps
10130A**Starter motor relay, Starter motor solenoid
10230A**Ignition switch power
10330A**ABS/AdvanceTrac® with RSC module (pump motor)
10430A**LH 3rd row seat relay, LH 3rd row seat switch, LH 3rd row seat motor
10530A**Power liftgate module, Power liftgate motors, Power running boards control
10630A**Trailer tow battery charge relay, Trailer tow 7-wire connector (battery charge)
10730A**Auxiliary A/C blower relay, Auxiliary A/C blower motor
10830A**Passenger seat motor switch, Passenger seat lumbar switch and motor
10930A**Driver seat lumbar switch and motor, Memory module, Power memory mirrors, Adjustable pedals switch and motor
11030A**Power running boards
11150A**Air suspension compressor relay, Air suspension compressor
11230A**ABS/AdvanceTrac® with RSC module (valves)
11330A**Front wiper motor, Washer pump (windshield wash)
11440A**Rear window defroster relay, Rear window defroster grid, Heated mirrors (Fuse 8)
11530A**Transfer case shift motor, 4x4 relays
11640A**Front blower motor relay, Front blower motor
11730A**RH 3rd row seat relay, RH 3rd row seat switch, RH 3rd row seat motor
11830A**Driver and passenger climate control seat module
40130A CB (circuit breaker)Power windows (circuit breaker), Main window switch, Window motors, Window switches, Moonroof module
R01Starter relayStarter motor solenoid
R02Delayed accessoiy relayFuse 22, CB 401, Power windows, Moonroof, Flip windows, Radio, Navigation module, Navigation antenna amplifier
R03Hi-beam relayFuse 35, Hi-beam headlamps, Hi-beam indicator
R04Rear window defrost relayFuse 8 (heated mirrors), Rear window defroster, Heated outside mirrors, Rear window defroster indicator (climate control head)
R05Trailer tow battery charge relayTrailer tow 7-wire connector (battery charge)
R06Front blower relayFront blower motor
R201Trailer tow park lamp relayTrailer tow 7- and 4-wire connectors (park lamps)
R202Foglamp relayFront foglamps
R203PCM relayFuse 32, Fuse 34, PCM solenoids and sensors
R301Trailer tow back-up lamp relayTrailer tow 7-wire connector (back-up lamps)
R302Heated PCV valve relayHeated PCV valve
R303Fuel pump relayFuel pump shut-off switch, PCM (fuel pump monitor), Fuel pump, Fuel pump driver module
R304Battery saver relayRoof rail lamps, Vanity mirror lamps, Map/Dome lamp, Glove box lamp, Cargo area lamp, Outside mirror puddle lamps, Instrument cluster (interior lamps)
R305Horn relayDual note horn
* Mini Fuses
** Maxi Fuses
Note: Relays R301–R305 are not serviceable components; see your dealer or a qualified technician for assistance.
Discussion Starter · #5 ·
That did work but I found a fuse that keeps blowing, fuse 32, which seems to relate to all the codes. Now I have to find a broken wire.
Discussion Starter · #6 ·
2005, 2006
Advertisements
1715 A*Foglamps
2310 A*RH low beam
2510 A*LH low beam
33Not used
* Mini Fuses
** Maxi Fuses
Did you ever get the starter to engage? If the engine will not spin over, nothing else matters. If the starter spins but doesn't engage, it can only be the Bendix isn't sending the gear out or the flywheel is missing teeth. Have you tried engaging the starter while out of the vehicle? I use jumper cables to check it and see if the bendix is working.
Discussion Starter · #10 ·
I did check the starter with a remote starter switch. The bendix was not working. I removed it and tested again outside the car and the bendix did work but the motor did not turn. I replaced the starter and fuse, the fuse blew immediately when the ignition was engage, I need to go through the wiring harness now. But don't have any wiring diagrams.
Yes it did. The fuse blows immediately when I use the ignition.
I realize you said 2005, my book is for my 2003. Unfortunately due to different engines, I would imagine there are some differences in wiring. The fuse box is completely different. To add to the issue, I know I saw it a couple of months ago, but can't seem to locate it tonight. I wonder if you could have pinched a wire taking the starter in and out? I would look for the areas you've been working in.
Found in an F-150 forum some information on Fuse32, seems to be the same control circuit. They stated that one of the sensors is probably shorted. However, then I found something much more likely since you mention water and all. The AC clutch, these do sometimes burn up and short out.
Sensor list:
Vapor Management Valve (VMV), A/C
clutch relay, Canister vent, Heated
Exhaust Gas Oxygen (HEGO) sensors
#11 and #21, CMCV, Mass Air Flow
(MAF) sensor, VCT, Heated Positive
(4.2L engine), CID sensor (4.2L
engine)
You might want to check the AC clutch and it's relay. Pull this relay (disables the AC clutch; no air conditioning) and see if that fuse no longer blows. It's possible the AC clutch is frozen, causing it's clutch to draw too many amps. It's relay #202, located in the engine compartment, left fender (drivers side). It's the leftmost relay. Check your owners manual for a pic of it's location.
Discussion Starter · #15 ·
Sensor list:
engine)
I will try that today, thank you.
I did order the shop manuals and wiring diagrams last night.
I forgot to mention, how they found the issue was to disconnect each of the items connected to the fuse. Then plug them back in one at a time until the fuse blows, last item is the issue.
1 - 16 of 16 Posts
