1 - 8 of 8 Posts
I need to disable my ABS system because my light comes on and stays one, sometimes the ABS braking kicks in even on dry pavement.
Someone mentioned that you can disable the ABS relay on a Ford Taurus. I’ve searched the net but I can not find where this thing is. It’s some type of fuse I’m guessing but a mechanic said it’s not gong to be in the fuse box. I was hoping I could find this myself.
Would anyone happen to know where it it?
Advanced Thanks
BA Fairmont ZL Fairlane
i dont understand why you would want to disable it for. ABS is a saftey system so to say it kicks in on concrete then it must be locking up?? instead of not locking up??? if there is a warning light then its one of two things: 1, there is an earth/shorting problem for the wiring, 2, it is failing and doesnt work properly therefor meaning you need to go get it fixed.
if you disable a safety system and are then involved in a crash even though it may not be your fault you will be held accountable as you disabled what could have stopped you crashing in the first place.
please explain further by what you mean "sometimes the ABS braking kicks in even on dry pavement."
Yes there is something wrong with it: Until I get $800 bucks to blow on an ABS system it is more unsafe to have it active then to just disable it as I was told by a mechanic who in on vacation this week.
Anyway I almost rear ended someone because the damn thing kicked in on a hot sunny day. Basically it only doses it when I first start driving my car and after about 5 min’s the breaks are fine yet the light still stays one.
You make a good point in the accident clams department but for now I need to turn it off because it’s more dangerous with it one.
Lots of people turn their ABS systems off even when they buy a new car.
And investigator can tell if an accident is related to breaks or not. If someone rear ends you, then who’s fault is that? ABS or NO ABS, the world is not a round place it’s very expensive when it comes to care parts, I'm still looking for the relay?
Sho'n Off
What year Taurus Do you have? Most of the major relays are in the little black box under the hood.
Hay 98shotoy, sorry I took so long, I thought you guys gave up on me.
It’s a 1995 3.0L 4 door taurus standard engine.
Sho'n Off
Not a problem!! Some nights I dont get alot of calls and other nights its busy.
Check under the hood for a small black box. It should be on the drivers side near the fender or battery area.
I have had numerous problems with my abs system. I have replaced the Module with a rebuilt/reprogramed unit that lasted approximately a year and a half. I had the same module rebuilt/reprogramed and it smoked when reinstalled. The company that rebuilt it said they never have that sort of problem to check the pump. Pump works, all sensors checked or replaced and still nothing. I purchased a used piece from a junk yard and it is working sporadically.
If I disconnect the relay under the hood does the relay control anything other than the ABS?
Asking for a
2000 Ford Mustang V6
1 - 8 of 8 Posts
