1 - 20 of 23 Posts
Ahhh another day, another dilemma.
Recently I noticed my coolant bottle was empty so I topped it up with some more coolant. About a week later I had another peek under the hood, and it was empty again :fraz: Filled it up... I just assumed that maybe there was a couple of air pockets in my system from when my sump was replaced and everything was pulled apart.
Again, a couple of days ago I was adding some tranny fluid and that's when I noticed the coolant bottle was again empty. So I added some water this time, and now it's gone back down to half way (two days or so later). There aren't any visible leaks, so I'm wondering if anyone has any ideas. If not, who will be able to find the leak ie. mechanics, radiator places??
:help:
400 kg ego
A professional pressure-check might be your best bet, as it could be anything. A radiator specialist would be well equipped to help.
Jim Mock You Rock
Yep go to a radaiator place.I had a similar dilemma and got it tested yesterday.Luckily the guy said the car is good..
Yeah go get a pressure test done. I'm losing water, no water on the ground though. The welsh plug on the back of the driver's side is leaking onto the cat and boiling off. But the coolant stains are a bit of a give away.
96 EF Futura
first thing id do is a pressure test, most likely cause is the radiator cap
HOPEFULLY it is not a headgasket, think positive
Formerly: SmokeEA
p4r4l3l said:
was only joking :p
When it comes to E series Falcons, thats no joke!
Yeah, i got same problem atm, have tigtened all my hose fittings and it seems to have slowed, but i still cant find it, no visible stains, no visible leaks. and Oil is clean as, ohwell, ill be rid of car soon, can be someone elses problem.
EB6
Have ya checked ya heater core that can leak into the air ducts and evaporate with out a sign except for a REALLY bad smell when you use your heater. Otherwise take it to a mechanic and get it pressure tested, were good at finding leaks and charging insane amounts an hour to do it.
Discussion Starter #11
Hmm well I am waiting for some more money before I get it pressure tested, I don't want to be sprung with a surprising fee. Where abouts is the heater core and how can I check if it is that? Are they easy to replace? Expensive? Don't wanna have to pull out the dash or anything hehe...
Heater core = inside heater box = Dash out job :p
Jim Mock You Rock
Ring up and find out how much.I went the other day and they did it for free.He was a nice guy.
Pimpin the chrome
Dash out is easy, just recently took mine out for the 4th time, and put it in the ea.
Luke you can tell if its ur heatercore if there is any dampness/ wettness under the heaterbox inside and/ or under the carpet (had it before).
Discussion Starter #17
Bloody mofo car =(... I have had a dampness in the driver's side footwell before, but couldn't source where it was coming from. I thought all the heater core etc was on the passenger side? Is it possible there could be a leak from a hose on the driver's side?
Sooo how can I get the leak happening again so I can find the stupid thing?!
WA Eseries Rep
I am loosing water but at a much slower rate, like once every two months I have to refill the bottle.
Think my problem is the head is slightly warped. I did the head gasket almost a year ago thinking that was a problem. But it is still using water, no sign of it in the oil. Look for a leak down the drivers side of the block its where mine is leaking.
Jim Mock You Rock
Footwell?inside or out? Is your coolant green?Is the leak green?
Pimpin the chrome
Luke, I know how to change the Heater Core over and also know how to do the dash , done it 5 times.
PM us if u need a hand ive got a spare Heater Core here you can have
1 - 20 of 23 Posts
