greetings allqwikcorty said:i was going to post the same thing soon, as in my acl kit it didnt include the steel pan gasket just paper ones.
another question, whats better, rope end seal or rubber?
The "Bird bath" only really matters if you run a "cast iron" factory manifold. As cast iron holds heat. Change the manifold to alloy and the problem doesn't exist.clevo said:I kept my metal gasket with the last manifold install, had to use a normal manifold gasket then the metal one over the top.
Is it really necessary? How much would it cool the manifold?
