I have a 1997 Mazda B4000, 4.0L V6, 4WD. The truck has two outside rearview
mirrors. One of them appears to be ever so slightly loose -- I adjust it
for a good view of the rear and after a few days of driving it has slipped
out of adjustment. Is there anyway to open these things and tighten the
mounts? These are the OEM mirrors -- the mirror is enclosed in a plastic
housing. They are manual adjust, not power.
Thanks.
Discussion Starter · #2 ·
http://www.therangerstation.com/tech_library/FloppyMirrors.html
Take a look at the second topic down on that webpage. It explains how to
take the mirror apart and fix the problem. I have fixed my own mirrors and
this should work for yours as well. I found that the biggest problem was
trying to get the Torx mounting screws out without messing the heads up,
best to give them a spray with Liquid Wrench or similar first.
Good luck,
Sharky
"Sharky" <[email protected]> wrote in message
news:[email protected]
> and this should work for yours as well. I found that the biggest problem
> was trying to get the Torx mounting screws out without messing the heads
> up, best to give them a spray with Liquid Wrench or similar first.
> Good luck,
> Sharky
Thanks. I'll give it a try tomorrow.
