If anyone has a question about mechanical problems on the Ford police cars I will try to help out with an answer, have been tinkering on them for 15 years!
So do you sand the inside of the lens?6SecCVic said:Well, actually...
(sorry to butt in)
Headlight yellowing can be eliminated by removing the headlight lens and sanding it with ultra-fine wet dry sandpaper. (Use about 3 stages from "coarse" 400 or so to just about the finest you can find.) Removing the lens is simple, and so is replacing it... just make sure that you have someone to help you line it up when you put it back in!
