1 - 20 of 20 Posts
spin 'em up
G Day all,
just a question about head gaskets,i heard that there is a metal head gasket u can get for 6cyl to replace the cork one, giving the engine more compression.
do you think that this is a good idea,i mean instead of blowing a head gasket something else might go,& and go in a big way.
Or the 2 metals might have a reaction under heat, what do u guys think.
fordboy.
Looking in YOUR bathroom.
the standard head gaskets are metal.
Your thinking of the rocker cover gasket.
wants a manual!
Metal rockercover gasket??? is there such a thing and would it even prevent oil leaks? i think he means the paper type head gasket with metal rings around each cylinder. i have heard of full metal head gaskets and they do give more compression. not sure how much though. dont think that they would have a reaction under heat either.
spin 'em up
i heard u can import them from the poms, they did the tickford inhance ments so they oviously know what they are doing, it would be worth looking into.
No longer around
he's thinking of copper head gaskets as used by top fuel and funny car engine builders.
mate, save youself a shitload of trouble.
do you plan on pulling you engine down every week??? because thats whay the top fuel engine builders do. one of many parts to be replaced every tear down is the headgaskets
just run a felpro or equivelant gasket kit through
spin 'em up
i said head gasket,mybe there not made of cork, but i know what i am saying.As for rocker gasket im running rubber not cork.
No longer around
was this directed at me? because if so, then please read my reply..........
i actually answered the question that you wanted answered
spin 'em up
Discussion Starter #9
no mate u were the most help thanks. i was directing it at walkinshaw
sorry dude, my bad.
Expesnive head gaskets can be a waist of $$$. The I6's dont need big compression. Stick to good quality monotorque ones.
spin 'em up
Discussion Starter #11
Walkinshaw said:
sorry dude, my bad.
no worries, good advice
ummm yhe get an au head gasket its triple layer steel
Two SC 61's = trouble
O ringing head helps with forced unduction if there are problems.But its aften other [detonation etc] issues why h/g blow...
EA-S MPI 5-Speed
****in, all ****s on here complain about head gaskets going.
people dont seem to figure out that if you maintain your cooling system proper you dont have any problems. its user neglect that is giving the e-series such a bad name with the head gasket trouble, ok the e-series head gaskets are a little more tempremental than others but ffs look after your cooling and you will have no head gasket troubles!!!!!!!
BoZZa17,
True, but not quite. With the different expansion rates of iron block and alloy head, gaskets are more apt to fail, in time, than with an iron block and iron head, like the good ole Windor.
cheers:beer:
As a mechanic of sorts :) and having many mates in the buisness, the most common causes for EAs blowing head gaskets are:
1) overheating, caused by blocked raiator due to either neglect or casting sand.
2) The fact that very few of the 3.9 block decks appear to actually have been straight.
Usually a Falcon which comes to me or one of my mates for a new h/g will also require the block to be faced. Personally I have twice replaced h/gs which had been previously done several times in the last year, and not had any trouble with the car again.
My 2c hehe
Alex
No longer around
i only said he will have head gasket's going because copper gaskets, like he was talking about, are verry much un reliable, on any motor.
they work really well in top fuel/funny car motors, but after about 3 runs there fvcked..... which is fine and dandy if you rebuild the engine every weekend.
copper gasgets work good with O rings etc and done right..
1 - 20 of 20 Posts
