That makes the two of us!strife said:me to
My set up is the same as yours M48pro,,,,,,,but l dont have traction control anymore cause of the 9" Detriot Locker l have on.strife said:Just a q on your setup
have you explored the traction and launch control options on the motec yet ?
Ive still got factory trac control working with mine but might loose it on the due to the gearbox swap (depending if we reflash the factory PCM
Setup is currently Motec M48pro, Ignition expander, 3bar map, air and temp sensor.
Will be commission idle control as well when new motor arrivies
