In swapping early motor mounts for late, the hole dimensions are the same but the angle for the outside holes seems to be narrower. In order to make them fit, the upper holes in the frame brackets need to be made oval on the same radius as the original upper hole. This will leave the late mount bottom edge horizontal to the ground.
Any comments? Has anyone out there done this swap? Did the holes line up exactly? Your experience is what I am looking for.
Thanks!
Thanks!
