The list I have for C codes does not show your codes ,
Ford C Chassis Diagnostic Fault Codes
Ford Diagnostic Trouble Codes DTCs (fault codes)
Chassis 'C' Fault Codes - Ford ABS, Traction Control, Ride Height etc
C0869 Air suspension auxiliary inflator indicator circuit failure
C1091 Wheel speed sensor all coherency failure
C1095 ABS hydraulic pump motor circuit failure
C1096 ABS hydraulic pump motor circuit open
C1097 ABS hydraulic pump motor circuit short to ground
C1098 ABS hydraulic pump motor circuit short to battery
C1100 ABS pump switch circuit failure
C1101 ABS hydraulic valve circuit failure
C1102 ABS acceleration switch circuit failure
C1103 ABS hydraulic brake switch circuit malfunction
C1104 Traction control active lamp - circuit short to battery
C1105 Traction control disable lamp - circuit short to battery
C1106 Traction control disable switch - circuit short to battery
C1107 ABS function enabled input circuit failure
C1109 Speed control actuator assembly cable release failure
C1110 ABS power relay coil circuit failure
C1111 ABS power relay coil open circuit
C1112 ABS power relay coil short circuit to ground
C1113 ABS power relay coil short circuit to battery
C1114 ABS power relay output short circuit to ground
C1115 ABS power relay output short to battery
C1116 Starter motor circuit failure
C1117 RPM input circuit failure
C1123 Vehicle speed sensor input short to battery
C1124 Input shaft speed signal missing/faulted
C1125 Brake fluid level sensor input circuit failure
C1126 Cruise control command switch assembly failure
C1127 Cruise control deactivator brake switch circuit failure
C1132 Clutch position ckt (circuit?) short to ground
C1133 Clutch position ckt short to battery
C1134 Gear shift position short to ground
C1135 Gear shift position short to battery
C1136 Gear select position short to ground
C1137 ECU is faulty (call BBA-reman for a test)
C1138 Gear select position short to battery
C1139 Wheel speed sensor center tone ring missing tooth fault
C1140 Hydraulic base brake failure
C1141 Wheel speed sensor LF tone ring tooth missing fault
C1142 Wheel speed sensor RF tone ring tooth missing fault
C1143 Wheel speed sensor LR tone ring tooth missing fault
C1144 Wheel speed sensor RR tone ring tooth missing fault
C1145 Wheel speed sensor RF input circuit failure
C1146 Wheel speed sensor RF circuit open
C1148 Wheel speed sensor coherency fault
C1149 Hydraulic fluid pressure / flow circuit failure
C1150 Two speed rear axle input switch circuit to battery
C1155 Wheel speed sensor LF input circuit failure
C1156 Wheel speed sensor LF circuit open
C1157 Park brake actuator assembly switch applied circuit failure
C1158 Wheel speed sensor LF coherency fault
C1159 Hyfraulic fluid pressure / flow circuit short to ground
C1161 Air pressure low circuit short to ground
C1162 Park brake switch #2 released circuit failure
C1163 Park brake switch #2 applied circuit short to ground
C1164 Park brake actuator assembly switch circuit failure
C1165 Wheel speed sensor RR input circuit failure
C1166 Wheel speed sensor RR input open circuit
C1167 Park brake actuator assembly switch released circuit short to ground
C1168 Wheel speed sensor RR coherency fault
C1169 ABS fluid dumping exceeds maximum timing
C1170 PRNDL (gear selector) switch circuit failure
C1172 Park brake switch #1 applied circuit failure
C1173 Park brake switch #1 released circuit short to ground
C1174 Park brake switch #2 applied circuit failure
C1175 Wheel speed sensor LR input circuit failure
C1176 Wheel speed sensor LR open circuit
C1177 Park brake actuator assembly switch released circuit failure
C1178 Wheel speed sensor LR coherency fault
C1179 Speed control actuator assembly cable slack failure
C1180 Park brake valve solenoid #1 sense input circuit failure
C1181 Park brake valve solenoid #1 sense input circuit short to ground
C1182 Park brake lamp flash relay circuit failure
C1183 Park brake lamp flash relay circuit short to battery
C1184 ABS in not operational]
C1185 ABS power relay output circuit failure
C1186 ABS power relay output open circuit
C1187 Brake fluid level sensor input open circuit
C1188 Brake fluid level sensor input short circuit to battery
C1189 Brake fluid level sensor input short circuit to ground
C1190 Wheel speed sensor LF input short circuit to battery
C1191 Wheel speed sensor LF input short circuit to ground
C1192 Wheel speed sensor RF input short circuit to battery
C1193 Wheel speed sensor RF input short circuit to gound
C1194 ABS outlet valve coil LF circuit failure
C1195 ABS outlet valve coil LF circuit open
C1196 ABS outlet valve coil LF circuit short to battery
C1197 ABS outlet valve coil LF circuit short to ground
C1198 ABS inlet valve coil LF circuit failure
C1199 ABS inlet valve coil LF circuit open
C1200 ABS inlet valve coil LF circuit short to battery
C1201 ABS inlet valve coil LF circuit short to ground
C1202 ABS outlet valve coil rear circuit failure
C1203 ABS outlet valve coil rear circuit open
C1204 ABS outlet valve coil rear circuit short to battery
C1205 ABS outlet valve coil rear circuit short to ground
C1206 ABS inlet valve coil rear circuit failure
C1207 ABS inlet valve coil rear circuit open
C1208 ABS inlet valve coil rear circuit short to battery
C1209 ABS inlet valve coil rear circuit short to ground
C1210 ABS outlet valve coil RF circuit failure
C1211 ABS outlet valve coil RF circuit open
C1212 ABS outlet valve coil RF circuit short to battery
C1213 ABS outlet valve coil RF circuit short to ground
C1214 ABS inlet valve coil RF circuit failure
C1215 ABS inlet valve coil RF circuit open
C1216 ABS inlet valve coil RF circuit short to battery
C1217 ABS inlet valve coil RF circuit short to ground
C1218 ABS lamp warning output circuit failure
C1219 ABS lamp warning output circuit open
C1220 ABS lamp warning output circuit short to battery
C1221 ABS lamp warning output circuit short to ground
C1222 Wheel speed mismatch
C1223 Brake lamp warning output circuit failure
C1224 Brake lamp warning output circuit open
C1225 Brake lamp warning output circuit short to battery
C1226 Brake lamp warning output circuit short to ground
C1227 Wheel speed sensor LR input short circuit to battery
C1228 Wheel speed sensor LR input short circuit to ground
C1229 Wheel speed sensor rear center coherency fault
C1230 Wheel speed sensor rear center input circuit failure
C1231 Wheel speed sensor rear center circuit open
C1232 Wheel speed sensor rear center input short circuit to battery
C1233 Wheel speed LF input signal missing
C1234 Wheel speed RF input signal missing
C1235 Wheel speed RR input signal missing
C1236 Wheel speed LR input signal missing
C1237 Wheel speed rear input signal missing
C1238 ABS hydraulic pressure differential switch input circuit failure
C1239 ABS hydraulic pressure differential switch input open circuit
C1240 ABS hydraulic pressure differential switch input short circuit to battery
C1241 ABS hydraulic pressure differential switch input short circuit to ground
C1242 ABS outlet valve coil LR circuit failure
C1243 ABS outlet valve coil LR circuit open
C1244 ABS outlet valve coil LR circuit short to battery
C1245 ABS outlet valve coil LR circuit short to ground
C1246 ABS outlet valve coil RR circuit failure
C1247 ABS outlet valve coil RR circuit open
C1248 ABS outlet valve coil RR circuit short to battery
C1249 ABS outlet valve coil RR circuit short to ground
C1250 ABS inlet valve coil LR circuit failure
C1251 ABS inlet valve coil LR circuit open
C1252 ABS inlet valve coil LR circuit short to battery
C1253 ABS inlet valve coil LR circuit short to ground
C1254 ABS inlet valve coil RR circuit failure
C1255 ABS inlet valve coil RR circuit open
C1256 ABS inlet valve coil RR circuit short to battery
C1257 ABS inlet valve coil RR circuit short to ground
C1258 Wheel speed LF comparison failure
C1259 Wheel speed RF comparison failure
C1260 Wheel speed RR comparison failure
C1261 Wheel speed LR comparison failure
C1262 Lamp warning relay circuit failure
C1263 Lamp warning relay circuit open
C1264 Lamp warning relay circuit short to battery
C1265 Lamp warning relay circuit short to ground
C1266 ABS valve power relay circuit failure
C1267 ABS functions temporarily disabled
C1268 Motor relay #1 circuit failure
C1269 Motor relay #1 circuit short to battery
C1270 Motor #1 input circuit failure
C1271 Motor #1 input circuit short to ground
C1272 Motor #2 input circuit failure
C1273 Motor #2 input circuit short to battery
C1274 Solenoid relay #1 circuit failure
C1275 Solenoid relay #1 circuit short to battery
C1276 Park brake actuator assembly switch applied circuit short to ground
C1277 Steering wheel angle 1 and 2 circuit failure
C1278 Steering wheel angle 1 and 2 signal faulted
C1279 Yaw rate sensor circuit failure
C1280 Yaw rate sensor signal fault
C1281 Lateral accelerometer circuit failure
C1282 Lateral accelerometer signal fault
C1283 Switch test signal failure
C1284 Oil pressure switch failure
C1285 Booster solenoid circuit failure
C1286 Booster mechanical failure
C1287 Booster pedal force switch circuit failure
C1288 Pressure transducer main / primary input circuit failure
C1289 Pressure transducer redundant / secondary input circuit failure
C1400 Traction control valve RF circuit failure
C1401 Traction control valve RF circuit open
C1402 Traction control valve RF circuit short to ground
C1403 Traction control valve RF circuit short to battery
C1404 Traction control valve rear circuit failure
C1405 Traction control valve rear circuit open
C1406 Traction control valve rear circuit short to ground
C1407 Traction control valve rear circuit short to battery
C1410 Traction control valve LF circuit failure
C1411 Traction control valve LF circuit open
C1412 Traction control valve LF circuit short to ground
C1413 Traction control valve LF circuit short to battery
C1414 Incorrect module design level
C1415 Incorrect module configuration
C1416 Damper RF short circuit to battery
C1417 Damper RF short circuit to ground
C1418 Damper RF circuit failure
C1419 Damper RF open circuit
C1420 Hydraulic fluid pressure / flow circuit short to battery
C1421 Damper LF circuit short to battery
C1422 Damper LF circuit short to ground
C1423 Damper LF circuit failure
C1424 Damper LF circuit open
C1425 Damper RR circuit short to ground
C1426 Damper RR circuit short to battery
C1427 Damper RR circuit open
C1428 Damper RR circuit failure
C1429 Input shaft speed input circuit failure
C1430 Damper LR circuit open
C1431 Damper LR circuit short to battery
C1432 Damper LR circuit short to ground
C1433 Damper LR circuit failure
C1435 Accelerometer rear circuit failure
C1436 Accelerometer rear circuit signal is not sensed
C1437 Accelerometer rear circuit short to ground
C1438 Accelerometer rear circuit short to battery
C1439 Vehicle acceleration EEC-IV circuit failure
C1440 Pressure transducer main / primary signal faulted
C1441 Steering phase A circuit signal is not sensed
C1442 Steering phase B circuit signal is not sensed
C1443 Steering phase A circuit signal short to ground
C1444 Steering phase B circuit signal short to ground
C1445 Vehicle speed signal circuit failure
C1446 Brake switch circuit malfunction
C1447 Traction control module request circuit failure
C1448 Lamp adaptive damping warning circuit failure
C1449 Traction control motor coherency fault
C1450 Traction control motor circuit failure
C1451 Traction control motor circuit open
C1452 Traction control motor circuit short to battery
C1453 Traction control motor circuit short to ground
C1454 Front lateral accelerometer circuit failure
C1455 Accelerometer front circuit failure
C1456 Accelerometer front circuit is not sensed
C1457 Accelerometer front circuit short to ground
C1458 Accelerometer front circuit short to battery
C1459 Adaptive mode switch circuit failure
C1460 Vehicle accelerometer power circuit failure
C1461 Vehicle accelerometer power circuit short to battery
C1462 Left front vertical accelerometer circuit failure
C1463 Right front vertical accelerometer circuit failure
C1464 Pressure transducer redundant / secondary signal faulted
C1465 Damper high side front circuit short to battery
C1466 Damper circuit failure
C1467 Damper high side rear circuit short to battery
C1468 Damper low side front circuit failure
C1469 Damper low side rear circuit failure
C1495 Traction control motor potentiometer circuit failure
C1496 Traction control motor potentiometer circuit open
C1497 Traction control motor potentiometer circuit short to battery
C1498 Traction control motor potentiometer circuit short to ground
C1499 Transfer case contact plate A encoder circuit failure
C1500 Transfer case contact plate B encoder circuit failure
C1501 Transfer case contact plate C encoder circuit failure
C1502 Transfer case contact plate D encoder circuit failure
C1503 Dynamic stability control left front valve malfunction
C1504 Dynamic stability control right front valve malfunction
C1505 Dynamic stability control left rear valve malfunction
C1506 Dynamic stability control right rear valve malfunction
C1507 Traction control of brake exceeds time-out
C1508 Traction control of engine exceeds time-out
C1510 Right front wheel pressure reduction performance problem
C1511 Left front wheel pressure reduction performance problem
C1512 Right rear wheel pressure reduction performance problem
C1513 Left rear wheel pressure reduction performance problem
C1699 Left rear sensor circuit short to battery
C1700 Left rear sensor circuit failure
C1701 Left rear sensor circuit fault
C1702 Right rear sensor circuit short to battery
C1703 Right rear sensor circuit failure
C1704 Right rear sensor circuit fault
C1705 Left rear center sensor circuit short to battery
C1706 Left rear center sensor circuit failure
C1707 Left rear center sensor circuit fault
C1708 Right rear center sensor circuit short to battery
C1709 Right rear center sensor circuit failure
C1710 Right rear center sensor circuit fault
C1711 Left front sensor short circuit to battery
C1712 Left front sensor circuit failure
C1713 Left front sensor faulty circuit
C1714 Right front sensor circuit short to battery
C1715 Right front sensor circuit failure
C1716 Right front sensor circuit fault
C1717 Left front center sensor circuit short to battery
C1718 Left front center sensor circuit failure
C1719 Left front center sensor circuit fault
C1721 Air suspension height sensor power circuit open
C1722 Air suspension height sensor power circuit short to battery
C1723 Air suspension height sensor power circuit short to ground
C1724 Air suspension height sensor power circuit failure
C1725 Air suspension front pneumatic failure
C1726 Air suspension rear pneumatic failure
C1727 Air suspension reservoir pneumatic failure
C1728 Transfer case unable to transition between 2H and 4H
C1729 Transfer case unable to transition between 2H and 4L
C1730 Reference voltage out of range (over 5v)
C1731 Air suspension LF corner up timeout
C1732 Air suspension LF corner down timeout
C1733 Air suspension RF corner up timeout
C1734 Air suspension RF corner down timeout
C1735 Air suspension LR corner up timeout
C1736 Air suspension LR corner down timeout
C1737 Air suspension RR corner up timeout
C1738 Air suspension RR corner down timeout
C1739 Right front center sensor circuit short to battery
C1740 Right front center sensor circuit failure
C1741 Right front center sensor circuit fault
C1742 Rear sounder circuit failure
C1743 Rear sounder circuit short to battery
C1744 Front sounder circuit failure
C1745 Front sounder circuit short to battery
C1748 Switch input circuit short to ground
C1749 Trailer input circuit failure
C1750 Accelerator position sensor out of range
C1751 Vehicle speed sensor #1 output short circuit to battery
C1752 Vehicle speed sensor #1 output short circuit to ground
C1753 Hydraulic clutch actuator valve signal fault
C1754 Hydraulic clutch actuator valve circuit failure
C1755 Power limit shutdown failure
C1756 Air suspension front height sensor high (SE) signal circuit failure
C1757 Air suspension front height sensor high (SE) signal circuit open
C1758 Air suspension front height sensor high (SE) signal circuit short to battery
C1759 Air suspension front height sensor high (SE) signal circuit short to ground
C1760 Air suspension rear height sensor high (SE) signal circuit failure
C1761 Air suspension rear height sensor high (SE) signal circuit open
C1762 Air suspension rear height sensor high (SE) signal circuit short to battery
C1763 Air suspension rear height sensor high (SE) signal circuit short to ground
C1765 Air suspension rear height sensor low signal circuit failure
C1766 Air suspension rear height sensor low signal circuit open
C1767 Air suspension rear height sensor low signal circuit short to battery
C1768 Air suspension rear height sensor low signal circuit short to ground
C1770 Air suspension vent solenoid output circuit failure
C1771 Air suspension vent solenoid output circuit open
C1772 Air suspension vent solenoid output circuit short to battery
C1773 Air suspension vent solenoid output circuit short to ground
C1774 Coolant temperature out of range
C1775 DC-DC converter failure
C1776 Heater system failure
C1777 Vacuum pressure circuit failure
C1778 Power steering failure
C1779 Blower switch failure
C1780 Temperature select failure
C1781 Engine coolant temperature signal missing / fault
C1790 Air suspension LR air spring/shock solenoid output circuit failure
C1791 Air suspension LR air spring/shock solenoid output circuit open
C1792 Air suspension LR air spring/shock solenoid output circuit short to battery
C1793 Air suspension LR air spring/shock solenoid output circuit short to ground
C1795 Air suspension RR air spring/shock solenoid output circuit failure
C1796 Air suspension RR air spring/shock solenoid output circuit open
C1797 Air suspension RR air spring/shock solenoid output circuit short to battery
C1798 Air suspension RR air spring/shock solenoid output circuit short to ground
C1800 Air suspension reservoir solenoid circuit failure
C1805 Mismatched PCM and/or ABS-TC module
C1813 Air suspension LR vent request exceeded max timing
C1814 Air suspension RR vent request exceeded max timing
C1818 Air suspension LR air compress request exceeded max timing
C1819 Air suspension RR air compress request exceeded max timing
C1820 Air suspension RF air compress request exceeded max timing
C1830 Air suspension compressor relay circuit failure
C1831 Air suspension compressor relay circuit open
C1832 Air suspension compressor relay circuit short to battery
C1833 Air suspension compressor relay circuit short to ground
C1834 Gauge drive current fault
C1835 Current sense circuit failure
C1836 Battery temperature out of range
C1837 Battery heater circuit failure
C1838 Charging system fault
C1839 Leakage fault
C1840 Air suspension disable switch circuit failure
C1841 Air suspension disable switch circuit open
C1842 Air suspension disable switch circuit short to battery
C1843 Air suspension disable switch circuit short to ground
C1844 Air suspension secondary front inflator solenoid output circuit failure
C1845 Air suspension front inflator solenoid output circuit failure
C1846 Air suspension front inflator solenoid output circuit open
C1847 Air suspension front inflator solenoid output circuit short to battery
C1848 Air suspension front inflator solenoid output circuit short to ground
C1849 Master cylinder pressure out of range
C1850 Air suspension warning lamp circuit failure
C1851 Air suspension warning lamp circuit open
C1852 Air suspension warning lamp circuit short to battery
C1853 Air suspension warning lamp circuit short to ground
C1854 Motor temperature out of range
C1855 Acceleration position sensor conflict
C1856 Traction motor encoder circuit failure
C1859 PRNDL input #2 circuit failure
C1860 PRNDL input #3 circuit failure
C1861 PRNDL input #4 circuit failure
C1862 Contactor circuit failure
C1863 External charging fault
C1864 Battery module fault
C1865 Air suspension rear inflator solenoid output circuit failure
C1866 Air suspension rear inflator solenoid output circuit open
C1867 Air suspension rear inflator solenoid output circuit short to battery
C1868 Air suspension rear inflator solenoid output circuit short to ground
C1869 Air suspension gate solenoid output circuit failure
C1870 Air suspension gate solenoid output circuit open
C1871 Air suspension gate solenoid output circuit short to battery
C1872 Air suspension gate solenoid output circuit short to ground
C1873 Air suspension RF air spring solenoid output circuit failure
C1874 Air suspension RF air spring solenoid output circuit open
C1875 Air suspension RF air spring solenoid output circuit short to battery
C1876 Air suspension RF air spring solenoid output circuit short to ground
C1877 Air suspension LF air spring solenoid output circuit failure
C1878 Air suspension LF air spring solenoid output circuit open
C1879 Air suspension LF air spring solenoid output circuit short to battery
C1880 Air suspension LF air spring solenoid output circuit short to ground
C1881 Air suspension RF height sensor circuit failure
C1882 Air suspension RF height sensor circuit open
C1883 Air suspension RF height sensor circuit short to battery
C1884 Air suspension RF height sensor circuit short to ground
C1885 Air suspension RR height sensor circuit failure
C1886 Air suspension RR height sensor circuit open
C1887 Air suspension RR height sensor circuit short to battery
C1888 Air suspension RR height sensor circuit short to ground
C1889 Air suspension LF height sensor circuit failure
C1890 Air suspension LF height sensor circuit open
C1891 Air suspension LF height sensor circuit short to battery
C1892 Air suspension LF height sensor circuit short to ground
C1893 Air suspension LR height sensor circuit failure
C1894 Air suspension LR height sensor circuit open
C1895 Air suspension LR height sensor circuit short to battery
C1896 Air suspension LR height sensor circuit short to ground
C1897 Steering VAPS (Variable Assist Power Steering) II circuit loop failure
C1898 Steering VAPS (Variable Assist Power Steering) II circuit loop open
C1899 Steering VAPS (Variable Assist Power Steering) II circuit loop short to battery
C1900 Steering VAPS (Variable Assist Power Steering) II circuit loop
C1901 Ride control RR shock actuator circuit failure
C1902 Ride control RR shock actuator circuit open
C1903 Ride control RR shock actuator circuit short to battery
C1904 Ride control RR shock actuator circuit short to ground
C1905 Ride control LR shock actuator circuit failure
C1906 Ride control LR shock actuator circuit open
C1907 Ride control LR shock actuator circuit short to battery
C1908 Ride control LR shock actuator circuit short to ground
C1909 Ride control RF shock actuator circuit failure
C1910 Ride control RF shock actuator circuit open
C1911 Ride control RF shock actuator circuit short to battery
C1912 Ride control RF shock actuator circuit short to ground
C1913 Ride control LF shock actuator circuit failure
C1914 Ride control LF shock actuator circuit open
C1915 Ride control LF shock actuator circuit short to battery
C1916 Ride control LF shock actuator circuit short to ground
C1917 Steering EVO (Electronic Variable Orifice) out of range fault
C1918 Air suspension ride height select swich circuit failure
C1920 Led #1 circuit failure
C1921 VAPS solenoid actuator output circuit failure
C1922 VAPS solenoid actuator output circuit open
C1923 VAPS solenoid actuator output circuit short to battery
C1924 VAPS solenoid actuator output circuit short to ground
C1925 VAPS solenoid actuator return circuit failure
C1926 VAPS solenoid actuator return circuit open
C1927 VAPS solenoid actuator return circuit short to battery
C1928 VAPS solenoid actuator return circuit short to ground
C1929 Air suspension front compressor relay circuit failure
C1930 Air suspension front compressor relay circuit open
C1931 Air suspension front compressor relay circuit short to battery
C1932 Air suspension front compressor relay circuit short to ground
C1933 Solenoid current out of range
C1934 HPU (Hydraulic Pump Unit) pressurisation failure
C1935 Chime circuit failure
C1936 Hydraulic pump relay circuit failure
C1937 Steering wheel angle sensor offset failure
C1938 Invalid steering wheel angle sensor ID
C1939 Brake pressure switch input circuit failure
C1940 Brake pressure switch mechanical failure
C1942 Unrecognized powertrain configuration
C1943 Airbag deployment indication input fault
C1944 Gauge driver circuit fault
C1945 Park switch indicates park with vehicle moving
C1946 Seat track position switch circuit open
C1947 Seat track position switch circuit short to ground
C1948 Seat track position switch circuit resistance out of range
C1949 Accelerometer sensor circuit open
C1950 Accelerometer sensor circuit failure
C1951 Lateral accelerometer sensor circuit open
C1952 Yaw rate sensor circuit open
C1953 Master cylinder pressure sensor circuit open
C1954 Master cylinder pressure sensor circuit failure
C1955 Steering angle sensor circuit open
C1956 Steering angle sensor circuit failure
C1957 Dynamic stability control valve RF circuit failure
C1958 Dynamic stability control valve LF circuit failure
C1959 Lateral accelerometer sensor circuit failure
C1960 Driver brake apply circuit fault
C1961 Park lamp relay coil circuit failure
C1963 Stability control inhibit warning
If yo put a 1 in front of the numbers, it would seem that you have a problem with the rear brake circuitry, please check the codes again and provide year and model if you can.
