1 - 7 of 7 Posts
I just rebuilt the top end of my motor and put a new cam in it. I tried to start it up and would start but won’t idle. I check the spark plugs and there bad. So I replace those and the wires and ignition coil because I was going to anyways. Now it starts up real well but dies immediately after. I’ve got it to stay idling twice but I drove it for 20 mins or less and it died and wouldn’t idle again once I reached a stop light. Any ideas what the problem could be ?
Have you checked timing? You may have gotten a tooth off and the timing could be retarded too much.
Administrator
Check that you have all vacum hoses attached and be sure you dont have any vacum leaks anywhere. Check around the Intake manifold for vacum leaks otherwise if it's a carby setup then there may be a problem there. Idle air bleed blocked perhaps.
RangersEdge
How steady is the timing at idle? If the mark is moving around it could be a worn distributor. Not a symptom of no idle (I'd vote for a vacuum problem), but a strong suspect for poor idle.
Klaus
72 Mustang 351C 2V AT AC Sprint Decor
1 - 7 of 7 Posts
