Hello eveyone
First of all I want to say I have been reading many of your posts which have been very helpful so thanks for sharing and help making a place like this to get some good info!
I own a 2003 Expedition, Eddie Bauer 4x4 5.4 triton 190K
I have an overheating problem that is driving me crazy and I am looking for some information if someone else had this problem, or can chime in and help!!!
Around last September, on a short drive the engine temp gauge went o full HOT, dropped into limp mode and the reduced power light came on. Within maybe 10 seconds of this, sometimes little longer, the gauge would drop back to the middle operating temp and then NEVER again run hot until an overnight park and engine cool-down. I checked the coolant right away when I got home and noticed it was quite low so I filled it up. Since then I have the same issue
I learned that if I get under the truck and pump the rad hose a few times BEFORE it overheats, I can clear some air from in the coolant, with a bubble or two coming out, and then it wouldn't overheat at all. The engine never runs rough, no sign of leaking fluid but the coolant does drop over a long period of time and I do smell a feint burning smell from engine bay- not exhaust. Been like this since I bought it (only put 2K in mileage on it). Also the day I bought it I had it pressure tested and it passed no issues
Since all of this, I have barely driven it in fear of making things worse.
This problem eventually turned into the coolant being pushed out of rad cap under too much pressure, even with the cap off. I initally thought head gasket so I had my mechanic do the air test from the coolant degas/overflow where if there is combustion gas in there is changes color. He said it failed this test and he told me head gasket
I started doing my own research and work on the truck and I am not fully sure he is right. Here is what I have done to the truck to eliminate things
Changed accessory belt
Changed oil
Changed thermostat (OEM Motorcraft)
Changed ECTS (engine cooland temp sensor)
Fully flushed coolant sytem and added new coolant (green 50/50)
Pulled and checked water pump
Back flushed both heater cores
Two OEM overflow caps
Double checked heater core vacuum valve is functioning
Put it all back together- same issue
Next I did cylinder compression test- all above 165, highest was 185. Not one cylinder side by side had a number to worry about
Tried leak down test- couldn't get conclusive results so aborted
After reading a few posts about the intake manifold water jacket issues, I decided to pull mine and see if that was it. I 100% have a bad manifold heater jacket that needs repair, but could this cause all of the air getting in there?
The top of the intake to the coolant crossover was where the issue is- NOT bottom of the manifold to cylinder head
See pics
http://www.fordforums.com/attachment.php?attachmentid=42042&stc=1&d=1430533502
http://www.fordforums.com/attachment.php?attachmentid=42050&stc=1&d=1430533502
After further inspection, The rear driver side coolant jacket seemed to have a crack in it? Could just be a cast line- not sure.......
http://www.fordforums.com/attachment.php?attachmentid=42058&stc=1&d=1430533620
Do you guys think the Manifold issue, which is common, could cause this air problem?Could it suck air? Would that make it fail the coolant/air test?
I read on some forum that a guy had this issue and he figured that when the engine was cool, air would get in through that gasket and create a bublle or pocket in the coolant system
Any advice offered is much appreciated!! Thanks
Discussion Starter #2
Sorry, forgot to add that when it over heats, every single rad hose (upper, lower, and all heater lines are COLD- not even warm)
The coolant, even though under pressure, is warm, not hot
The oil is clean both in the valve cover and dipstick
I get bubbles occasionally but not on cold start up, or consistently
thanks
That is definitely the place to start. Not uncommon to have a cooling system pull air into the system when cooling down through a leak source. Need to replace the manifold and reassemble. If you have access to a vacuum fill tool I would pull it into a vacuum to see if any other leaks are present
thanks for the advice so far- I plan os changingthe intake manifold to repair what I can see as two possible spots (both aT COOLANT CROSS OVERS) for coolant to leak out/air to get in
