I have a BF Typhoon and recently had a Flash Tuner installed with 60LB injectors. It has 279KW at the wheels which is about 60 better than what it had when I bought it. What would the next step be for me to get more grunt?
Administrator
I guess it depends on how much power you want and how much you want to spend. I'm thinking intercooler upgrades, fule pump upgrades and more boost. Have you spoken to your tuner about the power lvls you want to achieve.
i have a xr6 turbo with 315 at the wheels when i got a methonol injection for mine made quite a big jump bout 15 extra found that worth doing the methonol is like 30bucks for 20l which will last like 2 years
hi, you will need a dump pipe and hi-flow cat before the intercooler.. this should get you around 325rwkw.. then with a bigger intercooler you should get about 335rwkw....cheers
