Engine removal,never done this before on the 4.6L ford before.I have Ford factory manual that is telling me I need to pull engine and tranny together(T-45).But have a Hanyes book and it tells me no need to pull both together,what do I need to do?Also on this motor were is the proper place to install mounting brackets to lift the engine(can I use the mounting holes on the back were tranny meets the block,and Alternator mounting holes in the front on the block,is this safe?).I really need to lift from front to back (support),so I can angle the motor out with a load leveler.Does the radiator have to come out,it looks like it will clear.Everything is off and it is ready to come out.Thank you for any help or suggestions,c_shark1980.
