Hi, all. I just joined the forum in hopes to learn more about what has long been my favorite V-8, the 351C.
The car in question is a 1967 Mercury Cougar with a 351C/C4 swap.
My plan is to fuel inject and turbocharge the 351C. I’m going to go with moderate boost until I can put a built Cleveland between the shock towers.
I already have a Weiand single-plane intake manifold (mildly polished 2v ports) set up for port fuel injection, a custom made 1000cfm progressive rate throttle body, and fuel rails that all resided on a Accel DFI fuel injected Pantera for the last decade. The owner parted with his Pantera and sold me the DFI system.
I also have a dual-sync Accel DFI distributor and the wiring harness to tie it into the Gen 7 DFI system.
Having browsed your forum, I am very excited about the build. I know you guys had stock Cleveland heads that put our offerings to shame on the street (Do they call them Aussie heads in Australia? I bet not.
). But I had no idea you Aussie guys had aftermarket head options for this motor, let alone ones that appear (on paper, anyway) to flow as well as ported LS1 based heads.
I’m eyeballing a set of CHI 2v aluminum heads for my motor, but I want to start with a built proof bottom end.
What are the most cost effective options as far as selecting a block?
4-bolt main or 2, is it worth it?
Any preference for a nice hydraulic roller cam for a turbo motor?
If it helps, here are my goals:
I’d like to build a 600-700rwhp turbocharged motor on pump gas (intercooled with alcohol injection). I likely won’t spin past 6500rpm.
I’ll keep digging through the forum so as not to ask questions every other newbie does. Thanks in advance for your help.
Regards,
Justin
Regards,
Justin
