1 - 10 of 10 Posts
So my sister's car is a 2010 ford escape XLT and her AC was making noises and not turning on all the time, had a mind of it's own. we had it looked at, got it fixed, turned out the AC clutch was going out. ok, no big deal I figured that's what it was from the sounds.
fast forward a few months later AC stops working randomly again same as before stops working whenever it wants, no warning what so ever. Her dad comes down to help us take a look since we had just got it fixed and offers to pay to have it looked at again and fixed if needed. So we take it to the Firestone down the street(not our first choice just what he went with despite us warning him of the scams they get away with) and they say, oh yea it's the blower motor/resistor. We say oh ok cool we go through with the repair, they fix it up and it works again like it should... Right?
Nope does it again, same issue. We take it back to Firestone only for them to say it's the same thing and do the same repair again only to again a few weeks late shave it continue with the same issue. They're telling us we need to come in when it's not working so they can see what's wrong and see a master mechanic but because it's chooses when it wants to work or not, whenever we took it in it would randomly decide to work for them (just our luck).
Ok now we're present day. Still not working all the time. Wasn't working last 2-3 days. But today it decided to kick on. It gets extremely warm here in summer and my sister needs the AC, does anyone have any ideas as to what's going on or what/how to fix this?
One of the Firestone guys said it might be electrical issue and that made me immediately think maybe somewhere in the fuses maybe. But if that's the case why didn't firestone just check that initially as part of the look over the car before doing work? Please help!
When you say it doesn’t work what exactly do you mean? Is air blowing out the vents?
I mean like you can hear the compressor kick in but no air usually and if there is air its very very little like a breath of air through the vents but so little you can hardly tell
Is there air coming out of any place else? Sounds like a problem with the fan, not the compressor.
If it has a cabin filter , check it's not blocked or restricting air flow . Check all flap actuators are operating , for example
What exactly did they replace? If that fixes it I’d lean towards that even if it is temporary. There may be an underlying power or ground issue with that circuit.
If you think it may be the fuses or relays , here is the schematic for checking the various ones that might be related to your fault in case you dont already have it .
Ford Escape (2008 – 2012) – fuse box diagram
Year of production: 2008, 2009, 2010, 2011, 2012
Passenger compartment fuse panel
The fuse panel is located on the right-hand side of the center console, by the instrument panel.
Ford Escape - fuse box diagram - passenger compartmentFord Escape – fuse box diagram – passenger compartment
No.AProtected components
130Not used (spare)
215Brake on/off switch
315SYNC® module
430Moon roof
510Keypad illumination, Brake shift interlock (BSI), Passenger compartment fuse panel, SPDJB
620Turn signals, Stop lamps
710Low beam headlamps (left)
810Low beam headlamps (right)
915Interior lights
1015Backlighting
1110Four wheel drive
127,5Power mirror switch
137,5up to 2008: Canister vent
1410FCIM (radio buttons), Front display module, GPS module
1615Not used (spare)
1720All lock motor feeds, Liftgate release, Liftglass release
1820Heated seat
1925Rear wiper
2015Datalink
2115Fog lamps
2215Park lamps
2315High beam headlamps
2420Horn relay
2510Demand lamps
2610Instrument panel cluster
2720Ignition switch
285Radio
295Instrument panel cluster
305Overdrive cancel
3110Restraints control module
3210Rear video camera module
3310Speed control switch
345Speed control deactivate switch, ABS
3510Four wheel drive, EPAS (steering), Park aid module
365Passive anti-theft system (PATS) transceiver
3710Climate Control
3820Subwoofer/Amp (Audiophile radio)
3920Radio
4020Front power point
4115Driver/passenger door lock switches, Automatic dimming mirror, Compass, Ambient lighting, Moon roof, Camera display in mirror
4210Not used (spare)
4310Rear wiper logic, Heated seats relay, Instrument cluster
4410Not used (spare)
455Front wiper logic, Blower motor relay
467,5OCS (restraints), PADI (restraints)
Circuit Breaker
4730Power windows, Moon roof
Relay
48Delayed accessory relay
Engine Compartment Fuse Box
up to 2009
Ford Escape - fuse box diagram - engine compartmentFord Escape – fuse box diagram – engine compartment
as of 2010
NoAProtected components
A80Electronic power steering module (EPAS)
B125Passenger compartment fuse panel
115Heated mirror
230Rear defroster
320Rear power point (center console)
420up to 2008: Fuel pump
510Powertrain control module (PCM) – keep alive power, PCM relay, Canister vent (as of 2009)
615Alternator
715Liftgate latch
820Trailer tow parking lamps
950Anti-lock brake system (ABS)
1030Front wipers
1130Starter
1240Blower motor
1310A/C clutch
1415Trailer tow turn lamps
15
1640Cooling fan 1
1740Cooling fan 2
1820ABS solenoid
1930Power seats
2220as of 2009: Fuel pump
2315as of 2009: Fuel injectors
2410up to 2008: PCM transmission
255as of 2009: ABS
2615as of 2009: Ignition coils
10up to 2008: PCM mil
2710PCM – general powertrain components malfunction indicator lamp
2820as of 2009: PCM – emission related powertrain components malfunction indicator lamp
15up to 2008: PCM
2915as of 2009: PCM
up to 2008: Ignition coils
32
3510Run/start, Reverse lamps, Rear defrost relay
36
37up to 2009: Not used
Relay
20A/C clutch relay
21ARear defroster relay
21Bas of 2009: Fuel relay
21CBlower relay
21DPCM relay
30ACooling fan 1 relay
30BStarter relay
30CCooling fan main relay
30DCooling fan 2 relay
31AReverse lamp relay
31B
31CTrailer tow left turn relay
31DTrailer tow right turn relay
31ETrailer tow park relay
31FLiftgate latch relay
Diode
33PCM diode
34Start diode
Discussion Starter · #8 ·
No, no air anywhere else, like I said it has a mind of it's own when it doesn't want to work and when it does but when it doesn't it's pretty much completely dead like they never fixed anything in the first place it weird
Discussion Starter · #9 ·
We
Just had the filter replaced at an oil change/ tune up and I don't think it's the actuator because on the random chance it decieds to work everything else works fine it just doesn't turn on at all when it acts up
I would confirm all your connections to the motor are tight.
1 - 10 of 10 Posts
