1 - 8 of 8 Posts
The other day my oil pressure game went to low. and you can tell it's
not getting oil because you an here it in the motor. Sometimes when i
first start up the truck it had oil pressure just fine. After driving
for 10 or so minutes it drops to nothing. But if i shut off the truck
and start it back up it goes right back to normal.
Discussion Starter · #2 ·
Less time lookin for nookie, more time on maintenance?!
Clues may exist on dipstick and oil filler cap.
Foamy light chocolate? Black Sludge?
Yeh, I'm a Krusty old Geezer, putting up with my 'smartass' is the price
you pay..DEAL with it!
I'm not sure just when Ford went from a "real" oil pressure gauge to a idiot
light with an analog readout, but it probably was late 80s for the truck lines.
If there's a button type sender at the oil pressure output port, it's a fake
gauge that closes a switch around 7 psi and then reopens it at say, 5 psi. Put a
mechanical gauge on the oil pressure port and see if the readings are consistent
with the factory "gauge". If so, you have problems, ranging from a dirty sump
(oil pickup screen gets clogged) to worn main bearings or crankshaft. If not,
it's the gauge itself, the sender, or the sender wiring.
Discussion Starter · #4 ·
"Sharon K.Cooke" <[email protected]> wrote in message
news:[email protected]
> idiot
> lines.
> fake
> Put a
> consistent
> sump
> not,
Since the late 60's at least, '71 for sure.
Discussion Starter · #5 ·
Oil pickup screen is plugged.
For some reason, quite common on the 5.8/351.
I'll bet that's your engine...?
Rob
Discussion Starter · #6 ·
> > idiot
> > lines.
> > fake
> > Put a
> > consistent
> > sump
> > not,
No, they had idiot lights back in 1949 or so; I'm talking about the fake gauge
that's driven by an on-off switch like the idiot light, but appears to be an
actual needle-type gauge. That piece of trickery didn't happen until the late
1980s on Ford trucks, and Ford-made cars with apparent gauges in the early
1990s.
Discussion Starter · #7 ·
>> > idiot
>> > truck
>> > lines.
>> > fake
>> > psi.
>> > Put a
>> > consistent
>> > dirty
>> > sump
>> > If
>> > not,
> gauge
> an
> late
> 1990s.
Well I have an '82 pickup or bronco, or an 89 pickup, take your pick, with a
factory idiot GAUGE, not the light! If you need a picture the gauge and
it's sending unit, I'll gladly post if on a binary Usenet group for you. I
don't have my 71 truck anymore, The oil pressure gauge in that one may have
been after market.
Discussion Starter · #8 ·
> >> > idiot
> >> > truck
> >> > lines.
> >> > fake
> >> > psi.
> >> > Put a
> >> > consistent
> >> > dirty
> >> > sump
> >> > If
> >> > not,
> > gauge
> > an
> > late
> > 1990s.
> been after market.
Check the sender on the '89. It's most likely the button-type, and the "gauge"
in the cab is a fake. If it is a button (snap-switch) sender, look at one of the
Ford truck websites for a how-to conversion to a real gauge, or if it doesn't
bother you, do nothing.
1 - 8 of 8 Posts
