Ted wrote:
> No, very little difference at all; overdrive will increase gas mileage, but
> the effects will be the greatest at highway speeds. Think lower engine
> rpm=best economy. By the way, there is nothing to gain by cancelling
> overdrive operation in town, this is why it is enabled by default with every
> key cycle.
Actually I would guess the reason its back on after every key cycle is
so people won't drive down the hwy in 3rd. As for mileage it would
depend on your situation but it could lower your mpg if it lugs around
in OD. It is a fact with any automatic (without the torque converter
locked) it will get VERY hot going up a hill in overdrive, compared to
3rd(the converter is more likely to lock in 3rd too). If you don't
believe me install a trans temp gauge, then shortly after you will be
installing a cooler and downshifting to 3rd when going up hills
I
personally don't put it in 3rd around town but most of the surface
streets around here you hit 45 or 50 easy, there are no hills, and I
also drive my cars easy. If I am pulling a trailer I will always put in
in 3rd unless going down a flat stretch of hwy with the converter
locked. It is absolutly amazing how fast the trans fluid can get to 300
+ climbing a hill in OD.
