1 - 20 of 29 Posts
The SparkleHunter™
Gee wish I could rush out and buy one of those fantasic LS1 V8's...
Thanks to Drive.com.au
Holden oils up on V8 engine stress
First Published: The Age
Thursday, April 19, 2001
By ALASTAIR DOAK
Holden is expected to start putting more oil in its V8 engines in response to a number of failures brought on by high-stress driving.
According to the company, "dozens" of customers have run into trouble with the Corvette-designed, 5.7-litre V8 engine after heavy straight-line acceleration/ deceleration use. This treatment has caused oil surge in the all-alloy powerplant.
However, Holden stresses that problems have only been on vehicles with manual transmissions and that the company has acted quickly to fix any affected cars.
But it now seems the company is close to finding a solution for the problem and Holden engineers will recommend more oil be used to lubricate the engine to prevent the oil surge during heavy acceleration and braking. Adding additional oil would require a new dip stick with the "full" level moved further up the stick.
If the fix gets the go-ahead – the plan is expected to be approved in the next couple of months – Holden is likely to retro-fit the new stick to all Gen III-powered Commodores and Statesman/Caprice models.
So far, 20,934 Gen III-powered Holdens have been sold with almost 5,000 of those using manual transmissions.... Article continues but the rest is Holden crap...
Comments and piss-taking most welcome...
So if they change the dip stick in the engine, what are they doing to the dip stick driving the car? Everyone knows a Holden has two!
Pursuit Reincarnation Dog
Typical Holden. The 304s had major oil surge problems. So, let's fill up the oil a bit higher and hopefully :rolleyes: there will be a bit more oil at the pickup during hard driving.
I'd call the dipstick thing an accountant fix. The engineer's fix would be to fit a proper sump. Higher oil level = more internal 'friction' due to windage etc.
Which brings the question - are the 200 / 220 Windsor's any better??
The LS1 oil dramas have more to do with the pump design then the drivers and how the cars are being driven. To mu knowledge the manual part of the press statement is all BS unless we have the only 6 or 7 examples of auto failure in Aus. The problem with this is that the fault was know to Gm before those motors came to Australia:mad:
Administrator
Jeez oil surge in the sump has caused probs in many cars including some hi po Fords. I thought they had got passed all that by now. Baffles in the sump to prevent the oil surging away from the pick up fixed most of it.Even my stang from 71 has em as part of the Drag Pak option.If GM knew of the prob as well then you would think they would do something about it.If they made the dipstick long enough maybe it could poke a hole out the bottom of the sump.He He:wink2:
That story of manual LS1 cars having oil surge is total crap. I am a former Holden warranty manager and I know that it was heavy oil consumption that is causeing problems. The AFP put 2 engines in 1 car under 25000k and another 3 were looking at new engines. I also know a guy with an auto who lost oil pressure with less then 30 000k on it. This problem is also coming up in the US and GM Powertrain recently released a head service kit in effort to "fix" the problem. GM calims the LS1 is a 'nonrebuildable' engine!
Administrator
That is very very interesting FTEfan. Non rebuildable.What is that about. Is the LS1 a chuckaway motor when past it's use by date and that could be as low as 25000ks by the sounds.You have much inside information grasshopper.:mmm: :mmm:
Yes I personally know of two auto Ls1s that had the same thing happen to them. The number of these cars being affected is also being kept a very good secret.
:thumbdown
Note I said "GM CLAIM " the engine can't be rebuilt. The truth is with time and money it can and has been done. And to be fair I know a coulple that have been fine. Just don't rev them or try and tow with them.
The SparkleHunter™
Discussion Starter #11
So what you're saying is tha LS1 is a fantastic engine as long as she's parked in the garage?... :rolleyes:
The SparkleHunter™
Discussion Starter #13
FTEfan said:
Or maybe a boat anchor!:D
That's the best mod I've heard for the LS1 yet!!... :wink2:
Formerly J-type
OK guy's this is a bit off the subject but about a year ago a guy who works at a transmission repair garage told me that Holden were going to have a lot of problems with their auto, apparently (this is probably already happening) since the launch of the VT the transmission was made half out of normal metal and the other half aluminium, (I might be wrong about the materials) but anyway because of their design it's causing the gear box to shread it self apart. :mmm:
T5 Expert Operator
Geez sounds right, I had a VT for three months (company car) the transmission in that car feels like it's about to shread it self, shifting 1st to 2nd has a chronic diff knock and down shifting feels sounds like down shifting in a semi.
Yeah i'm not a fan of the holden auto i think it's the THM700. Auto in my dads EL is way better + a cruise control that is so convienient to use. :) :)
T
I have a question for you Mr Holden Man.
does increasing the amount of oil in the sump not also increase oil pressure in the sump also, resulting in power loss.
I think I'm right by saying that there is only 2 options left, a/ blow the sump off due to increased pressure, and b/ more blowby. but you knew that Mr Holden Man.
Cause your real smart.
sic's munce ago I could'nt spell mucanic and now I are one.
Holy mackerel batman! The LS1 now has kits to stroke out to 422 cubes and an easy 700hp street driven, no blowers or gas bottles.
That's not a boat anchor :eek:
Oh, and the Holden A4 is well and truly crap. Why people buy LS1s with A4 is truly a major question :WH:
Guess I must be old school as well. My old man told me to never over fill an engine with oil because you will over pressurize it and could cause seal failures. Some of the service people have been telling LS1 owners to add an extra .5 litre of oil to their car. I tried to tell them it sounded like BS. To me the full mark on the dip stick is full but I now notice that Holden plan to have new dip sticks made up with the new level indication marked on them. I am not sure how many oil problems the LS1 is having but I do know that of the two failures to friends cars both were cause by the relief spring in the pump breaking.
If the LS1 is so heavy on oil usage then they do have a problem, but the thing I can't get my head around is why Holden continue not to fit oil pressure gauges to their performance models.
T
HSE2
I think we may have gone to the same school.
on the other hand you can't tell holden drivers anything.
they know it all anyway.
1 - 20 of 29 Posts
