· Multi Car Owner
Would it work? Putting a computer out of a P71 from same years Vic into my 93 Marq? What would it do?:rocking:
· Grand Marquis Member
It should work just fine. It will raise your speed limiter from the factory 105mph to over 120+, not sure of the exact speed. (The Marquis and Civilian Vics are limited by the steel driveshaft, it has a vibration dampener on it that wouldn't like spinning that fast :))
It is also going to give you more agressive timing, later/firmer shifts, and raise your idle speed a couple hundred RPM.
The computer would have to be from a car older than '95. In '95 they went to the newer OBDII computers, and it isn't compatible with the older EECIV system.
