Supporting Vendor
PLX M−300TE Includes the main unit, with the display built in, wideband O2 sensor, dash or window mount, sensor harness, power wire, analog output wires & terminals, and the iMFD serial cable.
PLX M-300TE Tuner Edition Wideband Oxygen Sensor Controller with Display - $300.19
PLX M−300 Tuner Edition
DESCRIPTION:
The M-300TE (Tuner Edition) has 100% of the same features as the PLX Air Fuel Ratio Sensor Module with a built-in 4 digit display. It is fully compatible with other PLX iMFD gauges and can be daisy-chained with other PLX Sensor Modules.
PLX M−300 Tech Specs
  • Rugged aluminum construction
  • 8 selectable fuel settings
  • Compatible with iMFD gauges
  • Wideband 0-5V analog output
  • Narrowband 0-1V analog output
PLX M−300 Included Items
  • M-300TE main unit
  • Bosch wideband oxygen sensor
  • 10 ft sensor harness
  • 4ft power wire
  • Dash or window mounting hardware
  • User manual
  • 4ft analog output wires and terminals
  • 1ft iMFD serial cable
