OK THIS IS WHAT PEDDERS SAID NEEDS TO BE REPLACED
9934 GSR sealed strut x2 $183.60
2261 sports ryder coil sprin x2 $73.80
5800 caster/camber kit x1 $79.20
epf24 falcon d bush 24mm-2pk x1 $17.10
ep950 sway bar link pin bush-8 x1 $28.80
pbj292 pedders chassis part x2 $59.40
radius rod-control arm -4pkt x1 $28.80
contorl arm bush -4pkt x1 $32.40
power stearing rack & pinion x1 $378.00
gsr9080 gas sports ryder x2 $94.50
sports ryder coil sprin rh x1 $73.80
sporst ryder coil spring lh x1 $73.80
epf22 falcon d bush 22mm-2pk x1 $17.10
pf795 rubber bush -2pk x2 $40.50
p7593 rubber bush -2pk x2 $32.40
ep156 urethane bush x1 $49.50
fitting $1,009.25
wa- Wheel Alignment $45.00
total $3,040.56
with 10% disscount they said
i only paid $4,000 for the car but its in very good nic other wise.
the other thing is the head gasket mechanic recons between $600 to a grand.
just to replace the gasket. and get machiened
and she is burning power stearing fluid and might need a new powerstearing pump
at $ 239.40
if i was just going to get standard shocks and sprongs they recon i would save bout 2- 300 more but might aswell pay the extra to get it done.
so what u guys think of the price ?
ne i know of a cheaper place i should get a quote from in perth
i would really like to know
fitting $1,009.25
total $3,040.56
at $ 239.40
