I recently have problem with car charging, model 2017 Fusion Energi (VIN: 3FA6P0SU3HR329234). It used to get 100% charge within 2.7 hours, with V240/16A. Now I can have full charge only within 5-6 hours. Besides, the right side inside of the trunk gets overheated ( not sure what's in there, probably the battery). There were a couple of cases that left charger on in the garage, and the second charge was scheduled. So, it was double charged. The diagnostics show the following error code: P0D8F: 00-28: Battery charger, A cooling system performance. Can't find any info on this error, Googled everywhere. Maybe there's any module that was damaged?
Did anyone come across with such a problem? Hope you guys here can help me out!
Thanks!
Take it to a dealership for checking , possibly under warranty or covered by software update .
R.S Logan is right.
It takes specialized electrical knowledge to troubleshoot these things, not to mention the safety concerns of that big battery - and what would happen if you accidentally shorted across the terminals of that beast while working on the charger.
As expensive as a dealer is, that’s cheap compared to the consequences of what can happen when that much stored energy gets released in a few milliseconds.
I don’t mean to come off as negative, I’m just an industrial electrician and have seen first hand the damage a failed battery bank can do!
Stay safe,
Dan
