·Commie311: my car is running like SHIT.
Commie311: it will barely idle...
Commie311: but when i first turn it on, it idles fine in park
Commie311: until i put it in drive
Commie311: and then it will run shitty again until i put it in park, and even then sometimes it still will. Idles at about 250 rpms.
Commie311: black smoke out the tail pipe, sounds like its missing on about 3 cylinders, heh
Commie311: i just replaced the plugs, wires have about 20k on em but they wouldnt fail THAT quickly..
Commie311: could it be the disty?
Commie311: i'm hoping it isnt the timing belt
Commie311: it does suck in neutral
Commie311: its just slightly better because it idles a little higher there..
Commie311: still misses like crazy though
Commie311: its missing all through first gear. everything seems to run better when its above 3k rpms or so
Commie311: maybe its just harder to hear it missing. hm.
Commie311: ya, it just changes suddently...
Commie311: stalls all the time
Commie311: at like every intersection. its not driveable.
Commie311: argh! this is driving me nuts. and pt is down, ahh
Commie311: i have a disty out of a 95 gt sitting on my passenger seat in my car
Commie311: i could try putting that in and see if its better
Commie311: no MALF codes either
Commie311: will a 93 cap and rotor fit a 95 disty?
Commie311: it would never idle ok
Commie311: which it does every once in awhile, in park
Commie311: i'll go crazy tonight checking for vacuum leaks. wish i could do a compression test on it, dont have the guage though.
Commie311: i'll try the disty swap too
Commie311: stuck injector(s)? timing? disty? bad VAF? vacuum leaks? i dont know which direction to start in.
There's a more extensive post about it on probetalk, but this gives the basic idea. I'm almost sure it has nothing to do with the tranny. This problem seems to be at its worst when I'm not moving and the car is in park. At speeds of 40+ mph it's basically unnoticeable, although I'm sure its still misfiring and/or not running properly. Any ideas or suggestions are greatly appreciated.
