·Folks, if anyone has some advice for me, I'd appreciate hearing from you.
I am trying to pull a 5 speed standard tranny from an 88 Ranger. I have everything disconnected except for the "quick disconnect" fitting for the hydraulic clutch. The white ring that is supposed to depress to release the hydraulic line refuses to budge. I'v tried some penetrating oil and a home made version of the special tool, but nothing moves at all.
If it stays stuck, can I cut the line and not create a bigger problem? I assume I can put a splice in somehow.
Thanks for your help
