R
My sons owns a 1994 Ford Explorer and this past Dec. his car began to
run very bad and it was determined that he had a gasket leak in the
engine and the engine was shot/ gone. He then had a salvage yard put in
a used engine that had 88,000 miles on it. He got the car with the
new/used engine in late Dec/early Jan and last Friday his check engine
light came on. On Saturday we opened the hood and found that the
anti-frreze overflow container was empty.
I filled it up and now on Monday it is again empty and there have been
no visible anti-freeze on the ground underneath his car before the
check engine light went on, or now after i filled up the overflow
container.
Does this indicate that the used engine that was put in his car came
with a leaking gasket or some other problem and that the anti-freeze is
leaking into the engine/cylinders???
He has a 60 day warranty on the engine and is taking it into the
salvage yard tomorrow and do you believe that the shop should
fix/replace the used engine he had, or did his vehicle have some
pre-existing condtion that casued this problem.
Im not knowlegable about cars/engines so any help anyone can offer
would be greatly appreciated. Thanks in advance for any
help/information you can offer.
container.
