·Re: Disco 1 steering problem
I had a classic rangie that did this, it really felt quite unnerving, turned
out to be the rear axle ball joint. Isn't the easiest thing to check for
wear, but if you get a big bar and pry it to check for movement, if however
it is as bad as that one was, watch the rear tyre through the rear view
mirror at speed, you could see the body moving relative to the rear wheel,
not much but enough to cause some very iffy handling.
