J
Both the yellow REAR ABS and the red BRAKE ((!)) ((P)) dashboard lights came
on a couple of days ago. The brakes and the parking brake all seem to work
fine. I can engage and release the parking brake without a problem. No
noises or heat from the rear.
Weather has been wet and cold here in Cincinnati. The truck sits outside and
is not a daily driver. Maybe gets 3000 miles a year, to Home Depot and back.
1992 F-150 straight six, automatic transmission, standard cab, 138k miles
D
Discussion Starter #2
On Thu, 09 Feb 2006 00:02:48 +0000, Jim G rearranged some electrons to
form:
Check brake fluid level.
David M (dmacchiarolo)
http://home.triad.rr.com/redsled
T/S 53
sled351 Linux 2.4.18-14 has been up 1 day 12:27
J
That was exactly the problem. Should've checked it first. Thanks!
"David M" <[email protected]> wrote in message
news:p[email protected]
> form:
>> came
>> work
>> and
>> back.
> T/S 53
W
"Jim G" <Jim [email protected]> wrote in message
news:[email protected]
No that is the symptom of the problem. The brake fluid low enough to
trip the warning lights means one of two things, you have a leak, or more
likely, your front pads are worn out.
Whitelightning
J
Good point. I'll take a closer look at the entire brake system when the
weather is warmer.
"Whitelightning" <[email protected]> wrote in message
> Whitelightning
