Both rear door lock (electric) died. In the spring I took off the door pannel and sprayed them down with WD40 which help for a while now there dead again. Any suggestions?
have you checked to see if there was any electrical signal reaching the motors? also check the wiring for cuts or frays. check fuses. Fuses are an easy check you can do.
I already did that. The fuses are fine, there is current. The rubber boots on the solinoid are shot. If I spray them out with WD-40, I can get them to work for a while then they die.
