1 - 15 of 15 Posts
Not a Twink
Hi guys,
Can anyone recommend a good Turbo that will serve about ~ 500+ horsepower ?
Cheers.
Looking in YOUR bathroom.
for 500+ turbo your easiest route would be a GARRETT GT40. not cheap but can do 700bhp.
they can be flowed to aprox 700bhp iirc, that may be the GT42 though.
Two SC 61's = trouble
Mal has a gt40 and its rated to 600bhp send him a PM his is done and on road putting out 270kw at the wheels with 300+ no problem with new injectors & tuning.
Team Galaxy: Mad Bastard
Yep, Dazza's right...My AU XR6 is running a GT40 (rated at 600hp, might be 700hp but I'm not fussed), set at 10psi and already making 270rwkw at 4800rpm (9psi) as the injectors could not pump out any more fuel to bring the power curve up any further (bigger injectors going in soon plus a retune).
Sorry for camping on your post Honer. What turbo would i use on a 5.0 Au, would a gt40 do it or am i better to go higher. i only want to use low boost 6-10psi. what power could i hope to see.
I have a GT30 700hp turbo producing 330rwkw. It spools up slightly faster than the larger GT40, not sure about the cost difference.
Not a Twink
Discussion Starter #13
Cheers for the info guys.
If I told you what sort of engine it was for you would all probably end up chasing me down the street with pitch forks and stakes !
If a turbo makes 500hp ona certain motor it will do it on another.So within reason if you make 270 rwkw on a six you will on a 5 Ltr but maybe at lower rpm..Its all about cfm more than boost....
1 - 15 of 15 Posts
