Craig wrote:
> "Chris Whelan" <[email protected]> wrote...
>> Airmill wrote:
>>> I'm finding difficulties with my remote control for the doors in
>>> wintertime.Sometimes it doesn't function properly,it fails even every
>>> now and then.Someone having the same problem???
>>> Pim Luchtmeijer
>> Obviously the first thing is to fit a new battery! (CR2032)
> Always a good idea.
>> A new remote from a dealer, with the programming, will be about 100GBP!
> They're available on eBay quite cheap and can be self-programmed
> following
> the instructions in your Owner's Manual.
They often fetch 35-40UKP on eBay, but are only around 45UKP from a dealer.
Assuming we are talking about Europe, the instructions in the handbook do
*not* refer to reprogramming the remote function. They only tell you how to
make a PATS transponder key align with the immobiliser to enable you to
start the car. (You need two working keys first in order to program a
third).
The ability to program the remote part of the key is dependant on the make.
Ford have used at least two types, and at least one of those can only be
done at the dealer.
HTH
Chris
Remove prejudice to reply.
