Aussie Pete said:
......., Crow Cams never let me down.....
You're lucky Pete. I had a bad run with a couple of Crow Cams when I first "hotted up" my GT. The first one, which was all professionally installed and such, stripped a couple of lobes while I was still running it in. After Crow came to the party and ONLY paid for half a replacement, I was running again. Same cam specs as B4 which were "worked out" by a crow guy at the nats.
Come Dyno time and the HP wasn't there. (only 175kw at the wheels flat out).. So the guy who was at the dyno joint, Greg Waddington(Bendigo) sat down with the flow sheets of my heads and worked out a dual profile cam to best suit the car.This was a Wade cam, and the difference was unbelievable!! From just a cam change I gained more than 100HP at the wheels.
You can get what you want out of this blurb of mine, be it don't go for a catalogue cam and get a custom cam to suit your engine or Crow is crap and Wade is good. Or maybe nothing and I'm just waffling.
Russell.
